Originally Posted by aball4Runner
So I bought OEM replacement fog lamp assemblies. I am told I need relays and a switch. I would like to buy if you anyone has available. If you have any install insight please let me know.
FYI: My T4R does not have fog switch on Turn/Lights Stalk.
I also need clips to mount cross bars to factory rails on my 99' Base T4R.
its fairly easy to run 2 wires into the cab and add a little switch on the dash and just add a fuse from power to the battery
4Runner:1999 4WD 5VZ-FE SR5 5 spd man. E-locker, 4.56 gears, deckplate mod, gray wire mod, fog light mod,
12v mod, Skyjacker 2.5" block lift kit F&B, 2" BL, OME 891, Rola Vortex basket w/ extension, Hi-Lift jack, shovel,
chains, 23,000 lb recovery strap, 1st gen roll bar, 2nd gen tire carrier, 285/70/17 Hankook Dynapro ATM,
moto metal rims, 6 3.5x6", 4 hella 500 lights, HID 10,000k 35w
