08-16-2023, 05:50 PM
#16
Originally Posted by phattyduck
Looks like it peaked at 220*F, based on the image above, so I wouldn't worry too much about it right now. Still worth a drain and fill or two if the fluid isn't looking 100%.
The temp reported by the ECU is the HIGHEST temp the fluid ever gets - the sensor is on the outlet to the OEM cooler. The pan will be cooler than what is reported by the ECU.
Thanks for the peace of mind, Charlie - that's good to know. What temperature should I start to get worried, or at least pull over and let it cool down?
'99 Limited, 260k
08-16-2023, 06:09 PM
#17
Probably something like 240-250*F. The factory dash light comes on at 140*C/284*F for reference.
Generally though, you should try to keep it under 200*F for most operating conditions (cruising down the freeway, etc.), which is why many install a secondary cooler.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
08-31-2023, 04:48 PM
#18
Real Name: Jon
Real Name: Jon
Thanks charlie now know where to hook in my aftermarket transmission gauge to
get the highest temp reading...
08-31-2023, 10:11 PM
#19
Cooler line outlet.
08-31-2023, 10:32 PM
#20
Originally Posted by Bad Luck
I think your scan tool has switched sensor 1 and sensor 2 voltages. Normally sensor 1 voltage fluctuates as it senses and adjusts fuel trims and sensor 2 voltage should stay steady if your catalytic converter is operating as designed. Even if your catalytic converter is bad you should still see sensor 1 voltage fluctuating.
Luckers is correct. Weird how your scanner did that. Your downstream is monitoring two cats, which is retarded. If one goes bad you don't know which one. According to that almost too perfect to be true signal both cats are good. I would double check those values at the PCM or backprobe at the sensors to be sure. My heart would sink and I would punch myself in the mouth if my transmission fluid was dark and burnt. I like bright pink and clean magnets. The fluid doesn't work in that condition. Hopefully you haven't done damage.. Personally I do a full flush every ten thousand miles. And the filter needs changed everytime too. 75% of my mileage is trail, never had hot fluid.
09-04-2023, 09:31 AM
#21
Real Name: Patrick
Real Name: Patrick
Originally Posted by Jakeepoo3
Words
Please avoid quoting me in the future. Thank you.
09-25-2023, 10:23 PM
#22
Real Name: Robert
Real Name: Robert
....Beuller...?
Sorry, didn’t get notification of any replies in this thread.
This isn’t right. He has a front AFR sensor, which is not a narrowband O2 sensor that you’re describing. The AFR sensor is essentially a wideband O2 sensor. So as long as the AFR is constant, the output voltage reported by the ECU for bank 1 sensor 1 will also hold constant.
@ prybar
you need to rescale the graph so that minimum value is 0.40v and max is 0.80v. Stoich (14.7 for pure gas) will return a voltage value of 0.66v. If you know how to setup custom PIDs in that app, you can actually program it to interpolate voltage into actual AFR value, or lambda value if you prefer that instead.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
09-26-2023, 08:10 AM
#23
Real Name: Patrick
Real Name: Patrick
It's not a wideband sensor. Voltage will fluctuate for the upstream sensor as it changes and adjusts fuel trims. Feel free to provide a source for where it says that it's a wideband sensor though.
09-26-2023, 01:21 PM
#24
Dual cats = front sensor is wideband (well, not quite - it is an AFR sensor with a reduced range compared to true wideband sensors). They are on '99-'00 California emissions and all '01-'02 4Runners. The output of that sensor is scaled to narroband-style readings for reporting via OBD-II, but can be converted back to wideband with the chart above.
All '96-'98 and Federal Emissions '99-'00 had a normal front O2 sensor that will have the widely varying output voltage.
Check the FSM, wiring diagrams, etc. It is all spelled out there.
09-26-2023, 01:35 PM
#25
Real Name: Robert
Real Name: Robert
Toyota's Air Fuel Ratio sensor is absolutely a wideband O2 sensor. This is common knowledge on this board, or at least it was 10 years ago. Perhaps with a lot of the knowledge base moving on to newer vehicles, this has been forgotten. This is easily Google-able. In the earlier 3rd gens ('96-'98), the front O2 sensor was the traditional narrowband type O2 sensor. The 3rd gens that use the narrowband front O2 sensor can be readily identified by the fact that they have one (1) OEM catalytic converter. The B1S1 O2 readings on those sensors will oscillate between "high" and "low" and the narrowband O2 sensor does not have the ability to tell exactly what the air-fuel ratio is; only that is either rich or lean.
I believe it was in '99 (going from memory here) that the 3rd gens came with either the Federal Emissions or the California Emissions. Again, Federal Emissions used the traditional narrowband O2 sensor that should oscillate. The California Emissions used Toyota's "Air Fuel Ratio Sensor" that is essentially a wideband O2 sensor. The AFR sensor, unlike the traditional O2 sensor, can detect exactly what the air fuel ratio is at any given moment. The California Emissions vehicles can be identified by the fact they have two (2) OEM catalytic converters. The B1S1 O2 readings will be much more steady, and not bounce around like the older style narrowband O2 sensors. Instead, the reported voltage will correspond to the air-fuel ratio that I posted in the chart above.
At some point, I think it was either 2000 or 2001, all 3rd gens came with Air Fuel Ratio sensors, regardless of being Federal or California Emissions. Again, the fact that these 4Runners had two OEM catalytic converters readily identified them as having the Air Fuel Ratio sensors. Basically any 3rd gen that came from the factory with two catalytic converters has the Air Fuel Ratio sensor up front.
If it came from the factory with one OEM catalytic converter, then it has the older style narrowband O2 sensor up front. If it came from the factory with two, then it has the Air Fuel Ratio sensor up front.
In short, his scan tool did not switch the voltages between B1S1 and B1S2 O2 sensors. His scan tool is reading about what would be expected.
Reason: Spelling
09-26-2023, 02:26 PM
#26
Real Name: Patrick
Real Name: Patrick
Words and claims but no evidence provided
Still waiting on any sort of evidence to prove that it's a wideband. As far as I've seen and experienced it's just a normal range air/fuel sensor (for California emissions) or a normal oxygen sensor for everything else.
There's a difference in sensing range between a wide band air/fuel sensor and the air/fuel sensor that Toyota uses. If you aren't going to provide any sources to back up your statements then I'll see my way out.
09-26-2023, 03:38 PM
#27
Wow, way to be pedantic. It is a 'wide-band' in the sense that it is not a traditional O2 sensor. You guys are saying the same thing. Ok, so it doesn't sense 9:1 up to 20:1, it only is accurate from around 12:1 up to 18:1. The point is that it can accurately sense more than about 14.6:1 to 14.8:1.
09-26-2023, 03:50 PM
#28
Real Name: Patrick
Real Name: Patrick
When presented with a conflicting point of view/idea from what I've established through my own experience, research, and knowledge to be true then I require substantiated evidence to change that. A lengthy explanation of what someone thinks is great, but not really a verified source. Maybe if more people adopted this outlook there would be fewer people believing the moon landing was fake, the earth is flat, and aliens walk among us. Am I being difficult? Absolutely! If the roles were reversed I would provide outside evidence as well if someone required it. Should be pretty easy for him to provide it since it's "easily Google-able".
EDIT: Yes, I know I'm a dick/*******/etc.
09-26-2023, 03:51 PM
#29
Real Name: Robert
Real Name: Robert
LOL are you serious? So now you're acknowledging that it's an AFR sensor (and can report the actual air fuel ratio, unlike an older style O2 sensor)...
...which contradicts your prior post where you describe the operation of a traditional narrowband O2 sensor (and not an air/fuel sensor)...
So let me ask you this. Do you still stand by your statement that you think OP's scan tool is switching readings between sensor 1 and 2?
