Old 08-19-2023, 08:41 PM #16
Kwikvette's Avatar
Kwikvette Kwikvette is offline
Kwikvette will become famous soon enough
Kwikvette's Avatar
Pushed each relief cut out .0775" not to mention lengthening it by .125" and cut the real set out of 10 gauge
Afterward I bent and welded them up and now they're ready to go
Rear lower control arm bracket dimensions-20230819_162226-jpg  Rear lower control arm bracket dimensions-20230819_162727-jpg  Rear lower control arm bracket dimensions-20230819_172119-jpg  Rear lower control arm bracket dimensions-20230819_172153-jpg  Rear lower control arm bracket dimensions-20230819_172058-jpg
Kwikvette is offline   Reply With QuoteReply With Quote
Old 08-19-2023, 09:02 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't see why those won't work well.
Old 08-19-2023, 10:18 PM #18
poisedforflight poisedforflight is offline
poisedforflight is on a distinguished road
Originally Posted by Kwikvette View Post
So, I went ahead and cut up a test piece out of some scrap 1/8"
Only issue I ran across, which I planned ahead for was, performing the second bend on my brake
For that reason I added relief cuts to both sides and finished the second bend on my vise
End result ended up being 2.375" wide inside the wings
That's bad ass. i envy skills like yours.
poisedforflight is offline   Reply With QuoteReply With Quote
Old 08-19-2023, 10:21 PM #19
Kwikvette's Avatar
Kwikvette's Avatar
For sure; opted for something a little thicker too so they should last awhile
Old 08-19-2023, 10:21 PM #20
Kwikvette's Avatar
Kwikvette's Avatar
Much appreciated!
Old 08-20-2023, 03:39 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Build replacement frames at a reasonable cost, and you save many 3rd gens.
That's the problem, I don't doubt you can build them, the cost to mfg would b3 up there.
Old 08-20-2023, 05:40 PM #22
Kwikvette's Avatar
Kwikvette's Avatar
I'd gladly build parts to make up for those that often get cut out and replaced.
In fact, my favorite part of fabrication is making something from the ground up.
Old 08-21-2023, 10:18 PM #23
Kwikvette's Avatar
Kwikvette's Avatar
In case anyone stumbles upon this thread, want to add that I'd be happy with fabbing up some more.
Posted a thread on the other 4R forum about availability.
Can offer them in a completely flat, WIY version or offer them bent and welded.
Rear lower control arm bracket dimensions-20230819_162727-jpg  Rear lower control arm bracket dimensions-20230821_163255-jpg  Rear lower control arm bracket dimensions-20230821_163306-jpg  Rear lower control arm bracket dimensions-20230821_163320-jpg
Old 09-12-2023, 04:10 PM #24
Kwikvette's Avatar
Kwikvette's Avatar
Anyone happen to have dimensions for the upper link mounts?
Old 10-02-2023, 10:41 PM #25
Poor runner Poor runner is offline
Poor runner is on a distinguished road
Hey! just the guy I was looking for!
Recently found out that my passenger side upper control arm mount is cracked (seems like an epidemic).
If I got you a set of dimensions and a sketch could you fab one up? more than happy to pay.
Rear lower control arm bracket dimensions-bracket_back[1]-jpg  Rear lower control arm bracket dimensions-bracket_front[1]-jpg
Poor runner is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 07:09 AM #26
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
I would be interested in the upper mounts also. I had the passenger side break off but just welded it back on. It's been holding since June but would be happy to have replacements sitting on the shelf.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 08:57 AM #27
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
@eimkeith makes an upper trailing arm reinforcement kit as well as a lower arm frame bracket reinforcements...
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 04:20 PM #28
[QUOTE=octanejunkie;3814050]
If I got you a set of dimensions and a sketch could you fab one up? more than happy to pay.[/QUOTE @eimkeith makes an upper trailing arm reinforcement kit as well as a lower arm frame bracket reinforcements...
Sent from my Pixel 4 XL using Tapatalk
Props to you my friend and to @eimkeith . I don't know if this is a recent edition to his products but I don't recall seeing these when I picked up his lower link mount reinforcement.
-Stock Beater
Old 10-03-2023, 04:35 PM #29
[QUOTE=JustTroItIn;3814136]
Upper Link Mount Reinforcement – eimkeith.com
Old 10-03-2023, 05:17 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Guys, you can do what you wish. However, if those control arms brackets rust off or have holes in them. It's better to replace that steel than reinforce it. Well... It would be a lot more solid if replaced..
axle , cut , edge , housing , radius
Your thoughts on this rear lower control arm bracket / undercarriage? Reptile Christ 3rd gen T4Rs 8 03-16-2018 01:26 AM
Rear upper control arm bracket Beagle(4)Runner 3rd gen T4Rs 4 03-02-2016 02:11 PM
2nd gen rear control arm bushing dimensions? D Farms Classic T4Rs 2 06-27-2015 10:35 AM
rear lower control arm - where to buy? ghs215 4th Gen T4Rs 2 06-11-2015 01:30 PM
wtb right rear lower control arm mmjmeade For Sale: Suspension/Wheels/Tires 0 01-17-2012 07:48 PM
