No I just don't have the measurements as I replace the rear axle housings when they rust up.
You only gain 2 to 3 years max in the rust belt if you weld the brackets on or replace them.
As I had to replace 3 so far on 3 different 3rd gens. Then super clean the steel to seal off the oxygen so they last longer.
I am actually thinking of having this 3rd one power coated when I have all apart..
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
