Originally Posted by Ktfords
Hello all!
I just purchased a 96 toy 4runner and I have this situation with he cruise control. Usually if you have the CC on and going up a hill, it will change back and forth from overdrive to the gear below. Normally, I just hit the OD button and let it stay in the lower gear until I reach the summit with the CC on, this eliminates the trasmission shifting back and forth. My new 4runner, when the CC is engaged and approaching a hill I take the OD off, the car will lag for about 4 seconds and then take off. My other 4runners would not lag, this one does. It seems like the CC controller is delayed, hence the lag. I have adjusted the CC cable where it attaches to the throttle body, so there is not slack. Any suggestions?
Thanks
I would say your cc module or cable is about done. I have many 3rd gens and none of them do this.
The only other thing I can think of is your transmission kick down cable make need an adjustment.
What does the cc do with the ect pwr enabled?
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
