07-14-2022, 11:09 AM
official vendor
official vendor
Everything you always wanted to know about LBJ bolts
Which LBJ bolts are the strongest, how much torque should be applied during installation, and how much margin remains when the bolts are torqued to the recommended level?
These questions are the subject of some controversy on the 4Runner forums, but the answers are often speculation and opinion - until now. We are starting a series of tests over the next few weeks to gather data on bolt strength, torque vs preload, and torque to failure, to answer these questions (and more) about LBJ bolts.
We will be posting periodic updates here, but the majority of the details will be on our webpage - Everything You Always Wanted to Know About Lower Ball Joint (LBJ) Bolts - and More!
We will test five different OEM and aftermarket Lower Ball Joint (LBJ) bolts commonly used for the 3rd Gen Toyota 4Runner:
- Toyota 90080-10066 (replaces 90105-10406); Flanged Head Bolt; Green (1996-2000 4Runner)
- Toyota 90105-10505; Flanged Head Bolt; Red (2001-2002 4Runner, without boot)
- Toyota 90119-10933; Bolt with Washer (2001-2002 4Runner, with boot)
- Belmetric BF10X1.25X30YLW Grade 10.9 Zinc Plated Bolt
- ARP 663-1003 Bolt (8740 Chrome Moly)
In Part 1 of the test series, we will measure the torque vs. preload relationship for each bolt type. This will determine how much preload is generated at a given torque level, to see if some bolts are more "slippery" than others, and if a lower or higher installation torque value is warranted to obtain the required preload.
In Part 2, we will subject the bolts to destructive testing by measuring the torque needed to fail the bolts during installation. We will measure the actual torque required to fail the bolt, and document the failure mode (thread shear, tensile failure, etc).
Finally, in Part 3, we will test each bolt in an Instron machine to measure its tensile strength - the definitive indicator of bolt strength.
So stay tuned - this will be fun (and hopefully instructive!)
07-14-2022, 01:52 PM
You're my hero. Settling the debates once and for all!
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
07-14-2022, 02:05 PM
WOOOOO!
I was actually about to message you last night out of curiosity, haha. Can't wait to see the results and hopefully this will help save some guys and their trucks from disaster.
07-14-2022, 02:38 PM
I have a set of the ARPs in the garage waiting to go on the 4Runner, so I have a dog in this fight... (and accidentally overtorqued the currently installed bolts on one side of mine when I did the install years ago, so may have compromised hardware on there now)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
07-14-2022, 03:25 PM
It will be very reassuring to know when these bolts go from 'righty-tighty' to the very dreaded 'righty-loosey' state.
I guess the common failure modes on these LBJ bots are:
1) Overtorqued to the point the don't fail immediately, but are weakened and snap at some later point
2) Undertorqued, so the LBJ can start wiggling around in use and eventually loosen enough to fall off or shear* the bolts
* Shear strength of the bolts isn't being tested here, but that's NOT how the bolts are supposed to hold the LBJ in. Not even counting the locating collars on two of the bolt holes - the bolts are supposed to hold the LBJ so tightly to the upright that it won't move, not to prevent it from twisting by acting as a shear pin.
07-14-2022, 08:17 PM
Real Name: Robert');DROP TABLE Students;
Wait so “tighten until it starts getting loose again, then back off a quarter turn” is not the correct torque procedure?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
07-14-2022, 08:25 PM
Yes. Having actual data is gonna be rad. I might start logging in more often. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
07-14-2022, 11:34 PM
I'll take Door # 1 for 357,000 miles!
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
07-15-2022, 07:32 AM
I have the ARP's on mine now. I only have about 3 wheeling trips on them so far, but no issues with the OEM LBJs/ARP Combo.
You need the 35mm for the 01/02 LBJ with the Boot Protector.
30mm will work on 96-2000 without the Boot Protector.
The 4Runner Show
07-15-2022, 11:20 AM
Bringing real engineering know-how to an enthusiast discussion forum. I love it!
07-15-2022, 12:54 PM
official vendor
official vendor
We should be able to finish the torque vs. preload testing this weekend, so place your bets now - will they all be the same? We'll soon find out!
07-15-2022, 03:42 PM
We could probably go on all day...
07-16-2022, 09:31 AM
Interesting thread. I look forward to your findings.
I've replaced mine with Toyota bolts at every ~100k LBJ replacement.
Andreas
2001 SR5 4Runner 4WD, Dorado Gold, 546,XXX 1-owner miles
2002 4Runner, Dorado Gold, 226,XXX miles
1998 4Runner, Oxidized, 265,000 miles
2014 Audi A4 quattro, Monsoon Gray
1995 Porsche 993, Polar Silver
07-17-2022, 11:30 PM
official vendor
official vendor
We're having fun now! Just some teaser shots, I still need to do some serious data reduction.
