Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 09-24-2023, 04:26 PM #1
Brandt Brandt is offline
Junior Member
Real Name: Brandt
Brandt is on a distinguished road
Junior Member
Real Name: Brandt
What does this wire go to?
Hey y'all,
I'm toward the end of the months' long saga of replacing my 5vz. Installation of the new engine is next weekend, and I've discovered that a connector was pulled off of a wire. Connector is circled in the lower right corner of the image. Could someone please help me identify where this goes so I can order a replacement?
https://imgur.com/a/aHuCMfa
Oddly, I can't get the image to show up in the post, so a link will have to do
Brandt is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 10:33 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is offline
Elite Member
Real Name: Jon
brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute
Elite Member
brillo_76's Avatar
Real Name: Jon
For Future readers:
I found the harness piece I thought I had. I read these off the connectors as every connector first numbers are always 90980 -xxxxx
The female connector on the actuator switch part number 90980-11250
The second male connector up from the actuator switch part number 90980-11155
The connector off the main harness that Tim identified and phattyduck verified part number 90980-11156.
For the wire connectors pigtails, I add the Wire Harness Repair manual [RM1022E]
Hopefully, this will help others down the road..
I am also seeing another issue..tapatalk is leaving out comments or not always loading things. I never saw TheDurks additional comments on this thread until now with part numbers...Interesting.. Very interesting indeed. Unless the forum is not indexing correctly. Who knows. :-)
Sent from my SM-A536V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
brillo_76 is offline   Reply With QuoteReply With Quote
Old 09-24-2023, 09:20 PM #3
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
Thanks Brillo!
So, to clarify, is this the oil temp sensor connector?
Old 09-24-2023, 09:43 PM #4
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
Hm. I'm not able to get any hits for 5vz "ecu temperature sensor". Everything I find points to the coolant temp sensor. Would they use the same type of connector? If so, my real issue is solved.
Old 09-25-2023, 12:03 AM #5
TheDurk's Avatar
TheDurk TheDurk is offline
Elite Member
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
Elite Member
TheDurk's Avatar
Quote:
There are two coolant sensors. One goes to the ECU. The other goes to the temp gauge. Plus one on the transmission (slush box only).
The ECU one is this puppy here:
1991-2010 Toyota Engine Coolant Temperature Sensor 89422-35010 | Toyota Parts
[Incorrect info deleted. See newer post downthread.]
Please, ALWAYS give your year, engine, and 4WD/RWD and auto/5SP when requesting wiring help. Without that, anything I give you could be wrong. A close-up of the end of the subject plug would also have been real helpful.
__________________
'99 4Runner SR5 5spd 3.4L V6 4WD(U.S), original '99 Talls in front, OME 906s in back, Hella fogs, Trekmaster shocks in front, Billy in back, no running boards, FIAMM horns, Alpine sound, Michelin LTX M/S2's, owned since new.
'97 HiLux SW4 5spd 4WD(Japan model bought in Brazil assembled in Argentina, very close to a 3.0 4Runner/Surf)
'71 FordWillys Jeep CJ5 (with straight six Ford Maverick 3.0 liter engine--lives in the mountains north of Sao Paulo Brazil)
My Backyard Frame Swap
TheDurk is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 01:11 AM #6
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
Thanks for the clarification, TheDurk.
The ECT/ECU Temperature Sensor naming difference was throwing me off. But it does sound like we are talking about the same thing.
You're right, I neglected to provide those details. 99 5VZ 4wd 5sp. I'll remember for next time.
Unfortunately, it's the end of the plug that was ripped off and I'm trying to repair. I can't find the original, (lost amidst other components, I suspect) so I'm hoping that the photo of a stock harness would provide enough context.
Thanks again to both of you.
Old 09-25-2023, 09:45 AM #7
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
You're good, mate. I just didn't realize they were the same sensor.
Cheers!
Old 09-25-2023, 02:57 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Elite Member
Real Name: Tim
mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute
Elite Member
mtbtim's Avatar
Real Name: Tim
Now I feel the need to chime in. The ECU coolant temp sensor comes off the passenger side of the harness. What the OP has circled is the driver side of the harness. Based off my examination, that plug that is circled goes to the front differential actuator.
__________________
"My old man is a television repairman, he's got this ultimate set of tools. I can fix it!"
mtbtim is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 03:07 PM #9
phattyduck phattyduck is offline
Elite Member
phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute
Elite Member
Quote:
That looks right. Very easy to miss when pulling a motor since it is so far down there.
edit to clarify: That is for the ADD position switch, not the the ADD VSVs that are up on the inner fender.
-Charlie
__________________
'99 4Runner SR5 Auto - 4WD swapped
'89 Camry Alltrac LE 3S-GTE 5spd
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Previous: '88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, '03 WRX wagon, '08 Outback XT
phattyduck is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 05:16 PM #10
mtbtim's Avatar
Elite Member
Real Name: Tim
Elite Member
mtbtim's Avatar
Real Name: Tim
-Charlie
Yep, that plug is very easy to miss.
When I looked at the comments to the OPs question, I was like HUH? The ECT (Engine Coolant Temp) sensor plug comes off the harness on the passenger side and the plug the Op circled is clearly on the driver side all by itself. On the passenger side, the Knock Sensor plug and the ECT plugs are right next to each other.
__________________
Old 09-25-2023, 11:17 PM #11
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
I see references to "T" tab and Split tab variants of this connector. Does anyone know whether there is a universal connector available for this repair?
Old 09-26-2023, 01:06 PM #12
Elite Member
Elite Member
There's a small sub harness between the position switch on the ADD actuator (on the tube coming off the front diff towards the passenger side). You just need to repair that sub harness. Do it while the motor is out, otherwise access is very difficult.
I had damage in that same area on the parts truck that I got all my 4WD swap parts from (damaged by previous owner who took the engine - I wanted the rest of the truck for the 4WD parts...).
-Charlie
__________________
Old 09-27-2023, 12:32 AM #13
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
Unfortunately, I don't have any closer photos, or from a different angle. The challenge I'm faced with is that the connector was pulled from the wire and I'm unable to find where it ended up. So I have no direct comparison to find a matching replacement part. If I had that part, I'd probably just relieve the pins and pull them out, then re-terminate the cables and reuse the connector.
I did find this ebay auction. 4Runner ADD Differential Disconnect Vacuum Switch Valve CONNECTOR PLUG Pigtails | eBay
I wonder whether the t tab variant could be considered universal.
Any feedback on this?
Old 09-27-2023, 01:47 AM #14
mtbtim's Avatar
Elite Member
Real Name: Tim
Elite Member
mtbtim's Avatar
Real Name: Tim
Start watching this video at play time 26:25 to see how to access that wiring haness on the top of the differential that got damaged. You just have to disconnect the breather hose from the driver side fender well, disconnect the two vacuum lines at the switching valves on the driver side fender, disconnect the electrical connector at the ADD actuator and then take out the two bolts.
__________________
Old 09-27-2023, 08:59 AM #15
Junior Member
Real Name: Brandt
Junior Member
Real Name: Brandt
I think caused confusion with the photo link. The photo isn't of my specific harness, it's just an example photo for illustrative purposes. My wires aren't cut after the connector joint as in the photo. The connectors were disconnected during removal prep, and the part of the connector that was on the harness side is what was pulled off the wire. So one half of the connector is still on the car, and the other is missing.
Reply
Tags
identify , oddly , order , replacement , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Adapting a 3-wire gear driven VSS to a 2-wire electronic VSS harness? derekwilliams345 3rd gen T4Rs 10 01-11-2021 02:11 PM
Help, need to tab speed wire and ign wire behind dash Lawrence_Liang 5th gen T4Rs 5 01-19-2018 07:54 PM
Cigarette lighter wire tap - wire location? Nashvegas34 3rd gen T4Rs 7 03-03-2012 10:52 PM
How to wire speakers? Directly from amp or back to HU through stock speaker wire Woody17 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-18-2009 07:36 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
