Old 09-29-2023, 09:48 AM #1
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Partial elocker rebuild, worth it?
So I got a full locker with axle housing and I'm wanting to get it really well cleaned up and do somewhat of a rebuild on it but not go fully overboard. I have confirmed it works through bench testing so I don't see a need to actually take apart the motor and replace the gaskets in there and grease and mess with the headache of having it all reclocked properly. I do however want to get things more thoroughly cleaned (and possibly repainted, the third has surface rust) and there's a lot of nooks around that motor. this would I assume necessitate replacing at least one seal on the pinion going to the locking fork rack. Does anyone know a part number for that? Also likely want to do the main seal for the third to the housing, seems like that one is straightforward. And of course I will redo the axle seals and double check that my already rebuilt axle/drums will match up properly to the replaced seals. Is this really even worth it since the locker seems to work just fine? I just figured I have at least a month till I get my aftermarket harness and I still need to get a front diff with matching gears. Should I just do the axle seals and send it? For context the donor does have 363k on it (guy got into a front end wreck with someone running a light fleeing cops).
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 09-29-2023, 11:20 AM #2
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
with that many miles I would do what you are saying. the drums should match up fine
Old 09-30-2023, 10:23 AM #3
I guess the real question is do the dealers even still have that pinion seal for the motor?
'98 SR5 5 Speed
Old 09-30-2023, 09:40 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If the dealers don't have them. Places like marlin crawler or egs gear supply probably can get them...
axle , motor , properly , seal , seals
Top end Rebuild, not worth it? mendozer 3rd gen T4Rs 10 11-09-2020 08:02 PM
Elocker rebuild, hesitant to try arthurm 5th gen T4Rs 4 07-20-2018 12:05 AM
How much is the pumpkin from a 3rd gen elocker worth? MVP 3rd gen T4Rs 19 03-28-2018 05:55 PM
99 4x4 Limited w elocker Is it worth it ?? secretagnt 3rd gen T4Rs 17 05-03-2011 10:54 AM
elocker rebuild? jhaag Maintenance/Detailing 3 04-30-2011 08:11 PM
