10-01-2023, 12:08 PM
Real Name: Max
Real Name: Max
Broken Rear Lower Control Arm - Implications of Driving
UPDATE/EDIT: If you're reading this thinking it's about a broken Lower Control Arm, it's actually about a broken Upper Control Arm. I misread the suspension diagram, because I'm like that... /UPDATE
I broke my Rear Lower Control Arm (Toyota part #48720-35051) off-roading last week. Broke it on the same trail that broke my rear sway bar in June.
I have a replacement rear sway bar, but had not installed it mostly due to procrastination.
It looks like it's going to take a couple weeks to get an OEM replacement into my hands without paying my local dealer's rather excessive price (~$300).
I don't drive many miles during the week, but I'm wondering if I need to just leave the T4R parked until I get this replaced.
My questions for the knowledgable folks here.
- What are the implications of driving on-road with no rear sway bar and a broken rear lower control arm (passenger side)? Both safety and potential for additional suspension damage?
- Was the lack of a rear sway bar possibly a cause of the LCA failure?
Thanks in advance for your input.
2000 4Runner SR5 5-speed manual e-locker, 231mm Tundra brake upgrade, OME 881/890 Suspension, Stubbs Rock Sliders, TRD Supercharger
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 12:40 PM
Real Name: Tim
Real Name: Tim
You're not going to want to drive your rig with a broken lower control arm for the reasons you already mentioned. That would not be smart. Definitely wait until you can replace it.
As for what caused the control arm to break, the lack of the rear sway bar could have contributed to it, since you'll get more articulation from the rear axle without the sway bar.
I'm not familiar with Littleton, CO. Do they salt the roads due to ice there? If so, is your undercarriage being attacked by rust? Sway bars do break, but mostly what breaks is the end links on either end. Control arms break as well, but it's not terribly common. For those that do suffer breaks, I think corrosion a lot of times has something to do with it.
10-01-2023, 01:08 PM
I would think that driving with a broken rear control arm would make the rear of the vehicle extremely unstable and your rear wheel would probably be making intermittent contact with the wheel well. I wouldn't do it. Did you break it on a rock or something? A lot of people run without rear sway bars and this probably didn't contribute to your broken control arm. There are plenty of stories of bent rear lower control arms but rarely broken.
1997 Toyota 4Runner
10-01-2023, 01:18 PM
Some of the posts I see on this forum I have a hard time taking seriously so, that being said, a bit of a sarcastic comment is warranted here.
Sure, go ahead and drive it. You'll be fine.
But in all seriousness, nothing good can happen if you drive it like that.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
10-01-2023, 01:26 PM
Real Name: Max
Real Name: Max
Not much corrosion...
Thanks Tim. I'll park it until I get both rear LCAs and the Sway bar replaced.
In general my 4Runner doesn't have terrible corrosion considering how old it is , and mileage. But where the sway bar broke it looked like there was rust inside the bar.
The LCA, however, looks like pretty solid metal at the break point.
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 01:31 PM
Real Name: Max
Real Name: Max
I don't think I hit a rock... would have had to be a pretty tall and narrow rock to impact where it broke, and I think I would have been concerned about clearance generally if I'd seen such a rock approaching.
Seems like it was just metal fatigue/age?
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 01:37 PM
Wow! Those are interesting pictures. That looks like your upper rear control arm that's broken in the picture. PN#48720-35051 is for lower. And your right, not much corrosion. That's pretty crazy the upper control arm would break without corrosion or some form of trail contact.
1997 Toyota 4Runner
10-01-2023, 01:40 PM
Yeah possibly. Or could be a bad weld from the factory. I don't think I've ever heard of a broken upper control arm.
1997 Toyota 4Runner
10-01-2023, 01:58 PM
Real Name: Max
Real Name: Max
Fair enough.
The more I thought about it, the more I began to think driving was a Very Bad Idea, but wanted confirmation.
For the record, I didn't realize I'd broken it until last night. Worth capturing the experience in case anyone else goes through the same:
Last Wednesday, while climbing Mosquito Pass from the Alma side, about halfway up I heard a metallic "bang" like a rock hitting my sliders or something, but right away my Spidey Sense was triggered. A short while later another metallic BANG, and I started focusing in on that and when it happened again about 20 yards along I started getting that creeping dread feeling.
The weird thing was, I was sure it was coming from the right front side, and it really felt/sounded like a "binding" and then release, like the 4wd was experiencing some internal tension and then popping. Not good, for sure. I was in 4L and shifted to 4H and for a while nothing, then it happened again. I pulled off and crawled all around under the right front looking for any obvious damage but found nothing. This reinforced my belief it was internal/transmission/drivetrain.
Turned around and drove down and it made the tension-release BANG like 5 times on the way down.
At this point, I was convinced it was my transmission or 4wd.
At the bottom I put it in 2wd and did not experience the sound again for a while, further convincing me it was my transmission. Was already planning an appointment at my local 4wd shop. Then pulling into the grocery heard the BANG again. My passengers were convinced it was right rear and not front at that point.
Got under the truck and couldn't see anything, which was either because:
- It was dark.
- The LCA had popped back into alignment at that point
- I just missed it.
Now I'm thinking it's something in the rear differential. But the noises basically stopped at that point. In hindsight, that's because I was now on paved roads and there was ostensibly zero articulation.
Drove 80 miles home. No noises, no instability (that I noticed).
Pulled into my driveway and heard the BANG again. Now I'm finally thinking it must be the suspension. Maybe the rear spring? That's when I got under it again and noticed the LCA sheared.
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 02:12 PM
Real Name: Max
Real Name: Max
OMG. I'm an idiot. You're right. It is the Upper Rear Control Arm. I just referenced a diagram and totally mis-identified which part was which.
Who would have thought the Upper was higher than the Lower?
woof. I think I'll go hide for a little while.
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 02:21 PM
Just wanted to make sure you understand that is your rear upper rear control arm broken in the picture and you said you ordered a new rear lower control arm in your first post. The earlier responses were assuming you had a broken rear lower control arm.
1997 Toyota 4Runner
10-01-2023, 02:26 PM
LOL. No worries. Just wanted to make sure you get the correct parts for your rig. Meanwhile I did some google searching and apparently broken rear upper control arms are not that uncommon. Definitely going to be keeping a closer eye on mine from now on.
1997 Toyota 4Runner
10-01-2023, 02:27 PM
Real Name: Max
Real Name: Max
Yeah, I pretty much wasted everyone's time!! Sorry about that.
On the bright side, the UCA is cheaper.
I can imagine breaking the LCA would result in a lot of instability... and would be pretty hard to miss.
2022 Highlander
2002 Dodge Ram 1500
10-01-2023, 02:35 PM
Real Name: Jon
Real Name: Jon
I have had 2 rear upper control snap while driving down the road in the past. The original upper control oem are solid rods with weld around bushing bracket.
The lower rear control arms our pipes with the bushing bracket welded on.
It's not a good idea to drive around with a snapped rear upper control arm like everyone suggest as the extra stress can snap the other side off as well.
I can't say for the off reading world as the conditions are different. Those who do that would know the best course of action to take.
I replaced my rear uppers with aftermarket pipe versions because I have lost 2 in 2 different rigs that are not off roaded at all. Both snapped right at end of the rod where the bushing bracket attaches. Both were not siezed either. Went up and down no problem.
So far I had good success going this route. However, it maybe alot better to run oem style upper rear control arms in the off road world.
From my observations, it's better to replace them with the pipe style versions. I can let you know on about 5 or 6 years if the upper rear pipe control arms are better. I only have a few years on them now.
10-01-2023, 02:36 PM
Real Name: Jon
Real Name: Jon
Well all make mistakes. No biggie and no reason to hide...
