![Malcolm99's Avatar](https://www.toyota-4runner.org/customavatars/avatar564148_1.gif) |
if it is the blower that stopped blowing try a blower fan resistor, usually when they fail it would only work on high though. It is located in/on the HVAC box below the glove box, x2 JIC screws hold it in place, the ceramic can crack and fail.
