Old 10-09-2023, 10:57 AM #1
Nooga_Rock's Avatar
Nooga_Rock Nooga_Rock is offline
Nooga_Rock is on a distinguished road
Nooga_Rock's Avatar
2001 4runner idling high, sometimes won't crank, sometimes dies when I put in drive
When I crank my 4runner it sometimes won't crank, it just continues to try and turn over, it almost feels like its flooded. I'll let it sit for a second and it will always eventually crank after a few tries.
It also idles high, around 2k rpms. When i put it in gear it continues to idle high, and will drive faster than it used to with no foot on the pedal.
Sometimes when it's idling high in neutral and then i put it in drive it will die, or almost die and barely catch back on.
I do have a CE light on but it's been on a lot longer than this has been going on and the last time i checked the codes, before the idle problems, it said it was an evap issue.
Something else, which probably isn't related, is when im filling it up the gas handle always clicks too early. I usually have to pull it out a bit for it to not keep clicking off too early. I read this might be a charcoal canister issue.
I have tried cleaning the MAF sensor to solve the idle problem and it didn't fix it.
Any idea what's going on?
Nooga_Rock is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 07:22 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Start with seeing what codes you have. Then precede from there.
Old 10-10-2023, 12:37 PM #3
Nooga_Rock's Avatar
Nooga_Rock's Avatar
Okay I got the code P1135. Looks like an O2 sensor?
Old 10-10-2023, 01:50 PM #4
Nooga_Rock's Avatar
Nooga_Rock's Avatar
Yeah this looks like the problem. Sensor ordered. Looks like an easy install fortunately.
Old 10-10-2023, 06:37 PM #5
Your high idle could be a vacuum or since your rig is drive by wire there could be something up with the Throttle Body stepper motor or it’s full of sludge and can’t close all the way. High idle with the drive by wire is not fun to troubleshoot.
Look for cracks in the rubber intake track between the air box and the throttle body.
Is your scanner capable of reading live data?
Old 10-12-2023, 06:41 PM #6
Nooga_Rock's Avatar
Nooga_Rock's Avatar
Installed the sensor. Unfortunately it's still idling high and struggling to crank. That temporarily fixed the CEL, although I suspect it might come back since I cleared it after doing the MAF cleaning and it probably was only showing the O2 sensor code and I bet the evap code will come back in a few miles.
crank , drive , high , idle , put
98' 4Runner stalls/dies in Drive, while foot on brake 4VegasRunner General Discussions 4 07-03-2015 02:00 AM
Starts then dies. Will start an drive on 3rd, 4th try; will drive fine til ~1800RPM Ryan'004R 3rd gen T4Rs 4 07-16-2014 10:23 PM
Idling very bad in drive hynes9000 Classic T4Rs 0 03-15-2011 02:49 PM
idling high? ticotx Classic T4Rs 2 08-16-2010 08:51 PM
