Old 12-23-2023, 10:20 AM #31
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Those are OLD tires, keep an eye on them for signs that they're coming apart.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 01-07-2024, 12:46 PM #32
alex9000 alex9000 is offline
alex9000 is on a distinguished road
Yeah I ended up needing new ones for the inspection lol. Oh well, got some cool wheels.
I also installed an in line radiator hose heater yesterday because Alberta. It's only 350W but it was getting pretty hot last night when I tested it. Today it's 3F outside and will get down to -24F mid week so we'll see how she goes.
alex9000 is offline   Reply With QuoteReply With Quote
Old 01-07-2024, 07:41 PM #33
Installed this 1.25" in line coolant heater - although the lower rad hose internal diameter is 1 3/8"... I used high temp RTV and tightened the clamps quite tight. Around 0F today and it turned over with 2 cranks so I'm pretty happy with it
Alex9000's First T4R-c1112222apture-jpg  Alex9000's First T4R-5555capture-jpg
Old 01-08-2024, 05:34 PM #34
How does this work with a closed thermostat? Doesn't seem like you could get much flow through the engine/rad. It seems like you could do something like that on the heater hoses or bypass hoses though.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-08-2024, 10:33 PM #35
Texas3rdgen Texas3rdgen is offline
Texas3rdgen is on a distinguished road
Nice ride. I've been looking for a project 3rd gen and have noticed the prices coming down for the last 6 month.
Texas3rdgen is offline   Reply With QuoteReply With Quote
Old 01-09-2024, 01:04 AM #36
This is kind of what I was wondering about... So the thermostat shuts w/ engine off? I could re-locate it to a better location if that's the case
Old 01-09-2024, 10:52 AM #37
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thermostat opens when the coolant on the engine side of the thermostat gets hot enough.
Old 01-09-2024, 12:38 PM #38
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
Like @Bad Luck said, I've had one installed for yrs in the same location without issue.
clearock is offline   Reply With QuoteReply With Quote
Old 01-09-2024, 02:00 PM #39
It definitely won't cause an issue - I just wonder how effective it can be on the radiator side of the cooling system. It seems like one of the smaller units designed for 5/8" hose (heater hose) plumbed carefully would work better.
Old 01-09-2024, 07:51 PM #40
Next step... Installing the remote start. No immobilizer so it should be pretty straight forward...right
Alex9000's First T4R-compustar-jpg
Old 01-09-2024, 11:03 PM #41
Harnesses labelled and ready to get my solder on
Alex9000's First T4R-asdasdasda123123112-jpg
Old 01-10-2024, 07:04 PM #42
Only been driving the truck a few days now, dash clock has been out since i got it. Today it randomly lights up... I set the time then a few mins later it goes out again. Fast forward a few hours on the drive home it comes back to life and the time is still correct.
I seem to remember seeing a post about the spring connectors dying inside. Will need to take a closer look.
I'm also looking at replacing the cluster lights, just not sure if i want to go with LED since they might be too bright / not dimmable...
Old 01-10-2024, 09:39 PM #43
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
It's most likely not the springs in the clock. It's some of the resistors on the back. If you heat up each end with a soldering gun and reflow the solder your clock will work normally again.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-10-2024, 11:35 PM #44
Thanks. I'll take a look one day when I eventually drop that part of the dash.
Is there anything under the hood that could be responsible, say drivers side near the firewall? I was sitting there idling to warm up and heard a wooshing noise then the clock came to life. Weird I know... could be unrelated. What's the technical term for wooshing noise?
Old 01-10-2024, 11:47 PM #45
Not sure what that would be, but I'd say with nearly 100% certainty it was unrelated, the resistors in the clocks are a known weak point as the solder gets old and cracks, and sometimes will work when it's super cold.
281k Miles
Build Thread
front , offer , pump , struts , timing
