Old 01-11-2024, 12:32 AM #46
alex9000 alex9000 is offline
alex9000 is on a distinguished road
Originally Posted by RodrickHeffley View Post
Not sure what that would be, but I'd say with nearly 100% certainty it was unrelated, the resistors in the clocks are a known weak point as the solder gets old and cracks, and sometimes will work when it's super cold.
Yeah I figured it was probably the cold shrinking things back in to contact. Still a chin scratcher about that sound I heard though. Will keep my ears peeled!
alex9000 is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 11:10 AM #47
From 'perfect condition 4runner' to overheating on the commute. It was -30C overnight and looking at my inspection, my coolant was only rated to -15C so it likely froze. What burst, what's broken? Will find out soon
Alex9000's First T4R-coolant-png  Alex9000's First T4R-overheating-jpg
Old 01-13-2024, 03:07 PM #48
Prepping for the remote start install, still waiting for a few things from amazon. Was -50F overnight. Started up relatively fine. The overheating issue may have been a bubble as well, burped it a few times and put in some coolant rated to -50C. Pretty handy having a bunch of heavy duty mechanics at work.
Took apart the paneling for the remote install and ended up re-flowing the clock, extended the springs. The middle capacitor came right off the board when I re-flowed one side, so no wonder the clock was intermittent. Not the prettiest soldering I've done but my electronics tools are on the other side of the planet.
While taking apart the center console, I found (or tore out) what looks like an LED. There's also a small LED hole in front of my cup holders that I dont think is factory... is it?
Hopefully I get the relays in the mail today - just need to take off the driver's kick panel which I'm assuming I just yank on?
I know I'm preaching to the choir here but man are these trucks easy to work on. Love it.
Alex9000's First T4R-5-jpg  Alex9000's First T4R-1-jpg  Alex9000's First T4R-2-jpg  Alex9000's First T4R-3-jpg  Alex9000's First T4R-4-jpg
Old 01-13-2024, 03:10 PM #49
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
That LED is not factory, glad you got your clock working though.
To get to the kick panel you take off the door sill trim on the bottom (4 Phillips) and then just pull the panel towards the seat. I can't remember if the panel has a screw where it meets the sill, but it'd be pretty obvious to find once the sill has been removed.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-14-2024, 09:09 PM #50
Remote start successfully installed - took about 6 hours of messing around. Plus way more time reading and researching how and where to install what.
I still need to install the remote locks - waiting on diode from amazon. Then finally tap in to the Tach signal in the diagnostic plug in the engine bay so the starter can be sure the engine has turned on. Definitely need this in these cold temps.
Alex9000's First T4R-remote-install1-jpg
front , offer , pump , struts , timing
