Old 02-13-2024, 06:11 PM #31
Rahll's Avatar
Rahll Rahll is offline
Rahll is on a distinguished road
Rahll's Avatar
Clicking in rear was just a loose sway bar end link. Pretty best case scenario to have been alerted to the cv early and the culprit only being something easy.
Did atf with Valvoline multi-vehicle giga chad synthetic, running great so far, even had a small grind on hills resolve itself after.
Went to change gear oils, front diff bottom allen bolt completely stripped. Gonna return to that after I get a new bolt to replace it with.
Almost caught up with my current set of parts/fluids!
Rahll is offline   Reply With QuoteReply With Quote
Old 02-15-2024, 12:18 AM #32
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
Remember, pull the filler plug before the drain plug! If the drain plug comes out, great. If the filler plug doesn't come out, that drain plug just screwed you over, so to speak. Besides, if the drain plug is stripped out, what are the chances the filler plug is? Pretty good?
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 11:18 PM #33
Rahll's Avatar
Rahll's Avatar
Very beginning to now
Rahll's 98 SR5 4wd Build-comparison-jpg
Old 02-17-2024, 02:40 PM #34
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
Looking good! Helps that Anthracite is the sexiest color ;)
If you plan on keeping the basket (looks like a Rola Clone) you may benefit
by fabbing up some feet out of angle iron and bypassing the oem crossbars.
Mine is a decade old now and haven't had any issues whatsoever.
https://www.toyota-4runner.org/1712516-post226.html
Lots has changed since then, but the basket is still going strong.
keep it up!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 07:05 PM #35
Rahll's Avatar
Rahll's Avatar
Dealt with my stripped diff bolts today, gonna put on my breather tomorrow! I'm not sure how long its been since diffs and transfer case have had their oil replaced. Generally no sparkles but oil was definitely dirty. Small metal residue on each magnetic drain bolt but doesn't seem too concerning.
Rahll's 98 SR5 4wd Build-20240325_151519-jpg  Rahll's 98 SR5 4wd Build-20240325_125205-jpg
Old 04-03-2024, 12:19 AM #36
Rahll's Avatar
Rahll's Avatar
Here's where I ended up running the rear diff breather. Not sure if the ARB kit was fully worth the 70$ but happy with how it turned out. FYI the kit comes with enough fittings to run two breather tubes, not all 4. I just hooked up rear diff for now.
I also changed up my roof rack set up, and I'm really liking the new setup. It had been a short enough time for me to return my harbor freight rack (which was actually pretty nice just didn't fit my needs), and picked up a used Yakima Skinny Warrior for my driver side, and Yakima Bow Down kayak mounts for my passenger side. My board is 13 feet long and doesn't fit inside the truck. The bow down actually works surprisingly well and I was driving highway speed with no issues. The skinny warrior length is definitely better if you carry traction boards and a farm jack like I do, compared to the harbor freight rack. The traction boards actually sit all the way inside the basket with room to spare for gas cans.
Rahll's 98 SR5 4wd Build-20240326_104715-jpg  Rahll's 98 SR5 4wd Build-20240329_161915-jpg
4wd , build , functioned , sr5 , working
BEGINNING - Build on a Stock 4Runner! *UPDATED BUILD THREAD* bryanbgw 3rd gen T4Rs 27 11-22-2023 07:53 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
