Old 11-27-2023, 08:32 AM #1
Iffykid Iffykid is offline
Iffykid is on a distinguished road
First gear only when headlights turned on.
2000 3rd Gen Limited 190,000 when starting out with transmission cold if I turn the headlights on the transmission will not shift out of first or if going down the road and turn headlights on the transmission downshifts into first, dash indicator shows D indicator light but when headlights turned on D and R are both lit at the same time also if the high beams are on the high beam indicator is dim as well.
After 5-10 minutes driving with the headlights off I am able to turn on the headlights on and the issue seems to have gone away only to return the next day with the transmission cold.
Thanks
Iffykid is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 10:50 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
I would suspect a cluster issue. Try driving with the cluster unplugged and see what happens.
Old 11-27-2023, 02:25 PM #3
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
Assuming ur correct about the trans shifting and not shifting, i'd look for some type of GRD issue (at the batt 1st) as the transmission shifting and lights only common link is the electrical system +/- (to say they r completely diff systems that work independently and don't require the other to work, expect they both require +/- to work).
clearock is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 04:04 PM #4
Yup. I had somewhat similar issues on my '99 - it would lock and unlock the torque converter with the turn signals... and sometimes multiple gear indicators would be on.
New flex circuit on the back of the cluster fixed it. Likely a broken trace on the flex board...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-28-2023, 01:45 PM #5
As a nonmechanical newb where might I locate the connector to try and disconnect the instrument cluster?
Old 11-28-2023, 02:05 PM #6
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
You'd have to take some of the interior apart, there's four connectors on the back. There's a good video on how to do it on YouTube if you look for the video that entails how to swap the incandescent bulbs for leds.
You could try experimenting and see which of the connectors powers the PRND2L lights, I assume that with that connector disconnected you'd be able to narrow down the issue.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 11-28-2023, 10:57 PM #7
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Weird… electricity is so simple, yet continues to mystify
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 11-29-2023, 06:54 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Do you by change have Daytime Running Lights that have been modified or disabled? Could be part of the issue.
326WHP 347TQ
Old 11-29-2023, 09:33 PM #9
Daytime running lights were disabled a couple of years ago, 1st gear issue just cropped up about a week ago.
Old 11-30-2023, 01:27 AM #10
Real Name: Jerod
Real Name: Jerod
It sounds more like a grounding or gauge cluster issue, but if any wires are cut or modified (I don't know as I haven't done it) and short circuiting it could cause issues. I've done other wiring changes and I've had odd things like crank sensor codes because a wire was shorting out.
326WHP 347TQ
Old 11-30-2023, 10:57 AM #11
DRL was unplugged not cut.
blue/grey wire mod for rear locker several years ago.
trailer light harness added 10ish years ago.
Old 11-30-2023, 02:49 PM #12
Unplug the trailer harness while debugging... A bad one can also cause issues (leakage between different lighting circuits). Make sure tail lights are all working EXACTLY as you expect them too. (tails on/off, brakes on/off, turn signals - in all permutations)
headlights , indicator , transmission , turn , turned
All headlights go out when the high beams are turned on fishrod Classic T4Rs 15 08-19-2019 05:29 AM
Headlights turned themselves on after I shut it off Nashville5thGen 5th gen T4Rs 8 12-28-2018 06:37 PM
Do gauges dim when headlights are turned on? Cornelius 4th Gen T4Rs 10 12-22-2014 12:03 PM
headlights stay on after switch is turned off chass2001 3rd gen T4Rs 0 12-28-2007 04:23 PM
Can the foglights be turned on w/o the headlights? 4RNR4BB 3rd gen T4Rs 5 02-26-2005 08:06 PM
