Old 12-16-2023, 02:36 PM #1
power10er power10er is offline
power10er is on a distinguished road
97 Limited 4WD not engaging.
4wd will not engage. My limited has the two position TC with the 4wd engage push button. I get nothing when I press the push button on the shifter. No usual click from the relay/ecu and no actuator running sound either. The indicator light does not come on. The 4wd fuse is good. I verified the front axle does not lock in (spins freely). The VSV’s do not swap automatically, but I don’t think they’re ever getting the signal to swap since nothing happens from the push button. I did verify that the front axle does lock in when I manually swap the vacuum hoses at the VSV’s. (Does not spin)
I am leaning towards it being my 4wd ECU as the issue. Any other advice would be appreciated.
also, help me locate the 4wd ECU!!! Resources are sketchy on that.
thanks,
Brian
power10er is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 08:52 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
thanks,
Brian
Its possible its the ECU though it more on the rare side. I would suspect the actuator its self. As if it will not engage into 4wd. I would think the light would not engage along with the front VSV. Remove the actuator power connector and test for voltage while you have someone push the button on and off see if you are seeing 12 volts going to the motor actuator. If we have power at the actuator the brushes in the motor are most likely warn out and may need a replacement actuator. Testing is the only way to know for sure.
Old 12-19-2023, 05:57 PM #3
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
I haven't had to play with this on my Limited so not sure if it's the same but on my SR5 the culprit was the relay in the passenger kick panel.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
4wd , button , front , push , swap
4WD Not Engaging Xtremluck 5th gen T4Rs 33 01-18-2024 04:39 PM
2000 limited, trouble engaging 4wd with button Godog45 3rd gen T4Rs 1 10-28-2019 11:28 PM
H4 problem engaging with button ON 2000 LIMITED Godog45 3rd gen T4Rs 1 10-28-2019 09:17 AM
2000 limited, trouble engaging 4wd with button Godog45 3rd gen T4Rs 0 10-27-2019 05:14 PM
Engaging 4WD on v6 '05 Limited: rgcary 4th Gen T4Rs 7 03-10-2011 07:50 PM
