Old 12-22-2023, 01:15 PM #1
john_brandon's Avatar
john_brandon john_brandon is offline
john_brandon is on a distinguished road
Installing/Swapping New OEM Engine Fuse/Relay Box
I bought a used OEM engine relay/fuse box due to rear defog not working, but having a hard time finding details on the swap. I've found plenty info on acc fuse/relay installations but nothing on OEM replacement. Any help out there?
john_brandon is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 04:23 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Are you sure it's the relay box and not the wires that go from the body to the hatch in the rear? That's normally the culprit when something in the hatch stops working.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 08:07 PM #3
The rear wire harness is all good. Everything else in the rear works - window, lock, wiper. Checked the defog connections with the window, again all good. Heated mirrors also work, fuse for defogger is good but there’s no resistance at the defog relay. I’ve chased this problem for past two winters. Gotta be an issue in the box. I’m open to other ideas.
box , engine , fuse/relay , installing/swapping , oem
EFI relay / fuse t4rnoob 3rd gen T4Rs 31 03-05-2023 11:14 PM
Starter Fuse / Relay takumi 3rd gen T4Rs 19 09-30-2022 03:56 PM
Light Bar Relay and Fuse Wookiemonster 5th gen T4Rs 0 07-08-2017 02:12 PM
Is running a relay before a fuse block possible? What relay would you use? MightyP Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-28-2016 02:45 PM
What fuse relay box do you have? IronManKansas 5th gen T4Rs 20 03-24-2016 11:27 AM
