Originally Posted by RodrickHeffley
Are you sure it's the relay box and not the wires that go from the body to the hatch in the rear? That's normally the culprit when something in the hatch stops working.
The rear wire harness is all good. Everything else in the rear works - window, lock, wiper. Checked the defog connections with the window, again all good. Heated mirrors also work, fuse for defogger is good but there’s no resistance at the defog relay. I’ve chased this problem for past two winters. Gotta be an issue in the box. I’m open to other ideas.
