Old 01-04-2024, 10:25 AM #1
skippyenthalpy skippyenthalpy is offline
skippyenthalpy is on a distinguished road
Gauge and thermostat light replacement
Hey guys, what LED's have you all used (brand and bulb type, link if possible) that worked well for your gauges and thermostat lights? Preferably ones with little to no hotspots and aren't too bright for night driving.
Thanks!
skippyenthalpy is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 11:32 AM #2
elliottr06 elliottr06 is offline
Real Name: Elliott Rowland
elliottr06 is on a distinguished road
I used these ones from Amazon. They’re a little bright for the gear selection lights on the dash but they work great and look good. I chose blue so I don’t know how the other colors look but these worked good for me.
WLJH Super Bright Blue Instrument Panel Cluster Gauge Speedometer Tachometer Indicator Warning Lamp Bulb Full Led Light Kits Package for 1999-2002 Toyota 4Runner, Pack of 28 https://a.co/d/hB4CS1s
Gauge and thermostat light replacement-img_5839-jpg
elliottr06 is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 06:30 PM #3
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
In my experience any 194 and 74 bulbs worked just fine. I've dealt with three different colors of each across probably six different brands, and they all seemed to behave just fine.
The thermostat plastic ones seemed to be yellow in areas with my white LEDs, but I suspect that's because the actual plastic yellowed with UV exposure. I might try to whiten it with Hydrogen Peroxide some day.
So long as your dimmer rheostat works, which it should if your lights are coming on, you can just dim them to whatever you want.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-05-2024, 09:39 AM #4
Thank you ill check it out
Old 01-05-2024, 09:40 AM #5
Thank you, I just wanted some confirmation on the bulb type and dimmer situation because people are back and forth about how well some LED's work with the dimmer.
gauge , gauges , lights , preferably , thermostat
3RZ-FE Water Pump & Thermostat Replacement mtbtim 3rd gen T4Rs 2 11-21-2023 12:33 AM
V8 thermostat replacement? Medvedko 4th Gen T4Rs 3 08-25-2016 11:06 AM
Temp Gauge Fluctuating-Thermostat or No goatfarmer Classic T4Rs 5 03-30-2016 11:48 AM
Gauge Cluster / HVAC light replacement mod HYPE Anonymous4Runner 4th Gen T4Rs 0 10-21-2015 11:18 AM
Gauge and dash light replacement parkay Classic T4Rs 1 10-05-2014 09:48 PM
