Old 02-01-2024, 10:52 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting.. I haven't seen green brake fluid. :-) By any chance, are all your brake-lines changed to copper nickel lines? Maybe whatever brake fluid was used reacted with the copper lines. Its definitely have a green tint to it.
Old 02-01-2024, 11:10 AM #17
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by 19963.4lsr5 View Post
I’ve been using it for years…..
I was talking about the pool store info, I'm well aware of the difference between DOT3 and DOT4
Old 02-01-2024, 05:43 PM #18
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Welp, got the test strips today and according to them some copper is present but it's still way good. The camera picks up the color difference a little better but to the eye it was the exact same color as the 30ppm marking. Considering this and also how it's still much clearer than my previous bleeds, and the fluid is less than a year old, I wonder if my suspicions are right about old fluid still being trapped in the loop somewhere and is causing the rest to dirty up? I would still suspect the ABS box but I'm not sure if fluid passes through it continuously or if it bypasses it somehow and only mixes once the pump is tripped by the wheel speed sensors
I wish there was a way to bench test the pump, cause I can never get the damn thing to go off when I want to - only when I don't and I'm least expecting it
Green Brake Fluid-20240201_132629-jpg
Old 02-01-2024, 10:26 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The brake system is a closed. So its possible some fluid is staying in the system. Lots of people swear by gravity bleeding. I know both the late model and the abs in the earlier models are a nightmare to get the air out of. I wish there was simple way to activate the abs motors so that when your bleeding you get it all the first time.
Old 02-02-2024, 12:58 AM #20
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I assume there has to be a way to send voltage to it and get it to pump, because high dollar diagnostic tools like Autel and Snap-On can activate it remotely on the good majority of cars. I've never seen it done to ours in particular, but if it is true for us too then there has to be some way to do it without spending $5k-10k
At the same time, if there was a way you'd think someone would've found it by now...
Old 02-02-2024, 10:30 AM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The easiest way I found is gravel road and it will under certain conditions..:-)
Old 02-02-2024, 05:46 PM #22
The FSM procedure is a special SST that plugs directly into the ABS module... Nothing via OBD-II or the Toyota diagnostic connector under the hood.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
bled , fluid , green , pedal , time
Coolant, brake fluid and power steering fluid change and part numbers dcjeeper 5th gen T4Rs 0 03-05-2023 10:24 AM
Dirty brake fluid resevior, but clean brake lines BDow 3rd gen T4Rs 2 07-04-2015 01:08 AM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
Radiator fluid; Orange or Green??? BraveTraveler Maintenance/Detailing 3 10-17-2014 04:11 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
