Old 01-30-2024, 04:45 PM #1
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Alarm Goes Off With Hatch Open
Hi all,
Ever since I got my runner in '19, if I unlock the truck and only open the hatch, the alarm will go off after a couple minutes. My workaround has been to just open another door before opening the hatch and the truck will know that a door was opened and therefore not set off the alarm.
The part I don't get is that I would think it would have something to do with the door open switch, but my rear dome light will turn on then the hatch is open. So I am a little stumped. Anybody had this issue before? Ideas?
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 01-30-2024, 07:17 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by prybar View Post
Hi all,
It is a set time each time, or just a general time of a few minutes?
The wire that sends it up to the cluster, or in your case, the security system, might be breaking, which is common. It might just by chance be able to get enough of a current to trigger the alarm after a while.
Does the alarm re-arm after opening the door?
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-30-2024, 08:01 PM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Hi all,
If the back dome light is coming on, it might not just be the door switch acting up. There could be a glitch in the system or a sensor getting the wrong idea about the hatch. Give the wiring around the hatch a look for any wear or loose connections.
And, you know, if there's a sensor specifically for the hatch, that might be the troublemaker. Have you tried cleaning up the latch and making sure it's all good?
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 01-31-2024, 01:15 PM #4
prybar's Avatar
prybar's Avatar
I believe it is a set time, I have just never actually timed it, but I'll admit I'm not sure.
What can I do to test if it's the security system, and are there any known fixes?
I'm not sure what you mean about the alarm re-arming after I open the door. The alarm will go off if, after unlocking the truck, I only open the rear hatch and leave it open. However, if I open any other door then the alarm will not go off.
'99 Limited, 260k
Old 01-31-2024, 01:17 PM #5
prybar's Avatar
prybar's Avatar
I will take a peek at the wiring this weekend. I guess I'll also give the latch a look while I'm in there. Anything I should be looking for specifically other than damaged wires?
'99 Limited, 260k
Old 01-31-2024, 02:26 PM #6
What alarm are you using? (OEM RS3x00 or aftermarket?)
Sounds like the issue is happening when the truck re-locks the doors, which does happen after a set time if one of the passenger doors isn't opened (though it should also not happen when the hatch is opened - does the dash light indicate a door is ajar when just the hatch is opened?).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-31-2024, 02:54 PM #7
I believe it's a setting on the security systems to re-arm after fifteen seconds if a door wasn't opened, so I was thinking maybe it could be that.
If you're going to take a look at the latch, there unfortunately isn't much to look for. Habanero has a detailed post on her build thread that takes it apart and talks about it, but I think the easier option is to just replace the latch.
I'd give her thread a look and then decide what to do. I guess if you wanted you could always use a multimeter to test continuity on the latch closed vs open and see if there's anything weird going on there.
281k Miles
Build Thread
Old 01-31-2024, 04:17 PM #8
prybar's Avatar
prybar's Avatar
I believe this is what's happening. OEM alarm with the Toyota alarm stickers on the window. With only the hatch open, the dash does show the door is ajar. Is there something not communicating between the alarm system and the brain of the truck which knows the hatch is open? What could I look for?
'99 Limited, 260k
Old 01-31-2024, 04:19 PM #9
prybar's Avatar
prybar's Avatar
I think you're on the right track - the alarm definitely goes off when the truck goes to re-lock the doors since it thinks the hatch is closed for some reason.
Thanks for the advice. I'll check out her thread regarding the latch, give it a continuity test and maybe just grab a new one from pick-n-pull.
'99 Limited, 260k
alarm , door , hatch , open , truck
Rear hatch won't open. Jasonredwood 4th Gen T4Rs 67 06-12-2023 02:42 PM
Help!!! Rear hatch won't open. drtdvl 4th Gen T4Rs 170 07-26-2020 05:11 PM
06 - Back hatch won't open pyrakel 4th Gen T4Rs 10 07-16-2017 05:33 PM
Open Door Alarm When Accelearating BeachRunner10 5th gen T4Rs 10 05-29-2013 04:51 PM
Back Hatch won't open. marquezjol 3rd gen T4Rs 5 04-02-2013 11:11 AM
