Old 02-26-2024, 11:41 AM #1
OnTheEllipse OnTheEllipse is offline
OnTheEllipse is on a distinguished road
Fuel tank replacement? Rust? Considering starting a restoration project
Moved a couple of years ago and my 2001 has been doing a lot of sitting, mainly because I was getting a clunk and the shop I usually go to quoted me a sum of money that I wasn't prepared to pay at the time. It's been long enough that I can't recall the exact issue....control arms maybe? I remember looking at videos and there was a lot about bushings and bushing presses.
Anyways, I went to move the truck and gas started spilling out from under the back. I assume it's the connection from the gas line to the tank on the top of the gas tank. I've watched the videos on dropping the tank and working on that issue.
Other than those issues, it was in great working order. Interior was pretty nice. Less than 200k on the motor. There's a bit of rust underneath but I think it's manageable. With warm weather around the corner, more free time and money, I'm ready to get this thing rolling again.
I guess I'm just looking for advice to get started. Step 1 is fixing the fuel leak. I see replacement gas tanks in the 300 dollar range? Are those a good idea? I figure I might as well replace the fuel pump and the rest of the stuff attached to it while I'm at it.
And while the fuel tank is out, I think I'll try to mitigate any rust issues. Any advice or links to tutorials on that project? Wire brushes and spray/sealants? I'm handy enough but my abilities top at doing any welding.
Any other things to look out for or general advice would be appreciated. Not a ton of miles on, mostly good condition...so it would be cool to have it still on the road 10 years from now.
OnTheEllipse is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 08:41 PM #2
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
Find your fuel leak and go from there. I'm dropping my tank this spring also as I need to change the fuel pump. If that tank seems solid it's going back in the truck. I'll probably hit the exterior with some rust inhibitor and paint as it may buy some time (no guarantee, but I'm cheap). Bottom line, it's your money.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 09:17 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Very good idea to check out for rust while the tank is out. I am working on a 1998 4 runner frame in the gas tank area now.. The idea is to get steel coated and sealed before rusting.. The boxed frames love to rust from the inside out. So keeping the frame clean inside and out will help keep the oxidation down. Rust convertors help but the main thing is to keep the steel sealed off from oxygen. This is what paint and the coatings do. Rust inhibiting solutions are your best bet to keep the steel from rotting away.
Old 02-28-2024, 12:34 PM #4
Kmurt's Avatar
Kmurt Kmurt is offline
Kmurt will become famous soon enough
Kmurt's Avatar
I just went through this process and documented everything here: Gas Tank Replacement Journey
2001 4Runner SR5 4x4
2019 4Runner TRD Offroad 4x4
Kmurt is offline   Reply With QuoteReply With Quote
Old 02-29-2024, 08:17 AM #5
Dude, amazing! Thank you so much! Extremely useful
advice , fuel , gas , rust , tank
Fuel Tank Strap Replacement Tutorial (60+ Pictures) y=mx+b 4th Gen T4Rs 100 04-20-2024 12:21 PM
Fuel Tank Strap Replacement. Maineiac 4th Gen T4Rs 6 04-22-2021 05:41 PM
Fuel tank strap replacement Porqupine82 4th Gen T4Rs 0 10-18-2016 09:44 PM
Replacement OEM Fuel Tank Skid Plate fdbyrne 4th Gen T4Rs 5 12-24-2015 12:45 PM
Fuel tank replacement kendrick1961 3rd gen T4Rs 4 10-21-2014 07:14 PM
