Old 03-26-2024, 07:51 PM #1
D'arce D'arce is offline
D'arce will become famous soon enough
leaking transfer case
My 96 mt, 2.7 transfer case is leaking from the front input. I'm having a hard time finding parts or a rebuild kit.
I saw a post about a Rock-Auto rebuild kit so I looked it up and its calling it an R100. Not sure what to think about that. Parts-geek shows some seals but no bearings. I believe the J-shift is a VF2A. Looking for some guidance on parts or rebuilt units. What are folks doing with these? Mine just hit 285k.
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
D'arce is offline   Reply With QuoteReply With Quote
Old 03-29-2024, 09:25 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When I resealed the my transfer case. I just bought the front seal off of Toyota. Mostly they are not crazy expensive. :-) Granted, there maybe some options. Rock auto has it listed as a transfer input seal with 3 options if you wish to go that route as well. :-)
I have only really seen the input and output seals leak so far. I am sure the chain cover seal can seep too but I would imagine the transfer case would have to get really hot to cause that to leak like running low or out of gear grease.
So your thinking the bearing input is bad? I know I would test that before replacing it. Its possible because of the age now, its just the oil seal ... :-)
Old 03-30-2024, 03:45 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Not sure if you already have the transfer case out, but if you don't, my video will help you out.
Old 04-01-2024, 09:19 AM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@D'arce I put in characteristics I believe are correct search by VIN if not. TOYOTA 4RUNNERRZN185L-GKMSKA - POWERTRAIN-CHASSIS - TRANSFER CASE EXTENSION HOUSING | Japan Parts EU
I take OE numbers and cross reference to suppliers Roc has their info tab.
285k is not bearing needing milage if T/C been kept full or near it under most use conditions.
Seals weakest link judge bearings when TC out. How I'd roll.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 04-04-2024, 05:09 PM #5
I have only had this truck for 15k miles or so. All the fluids were full, just filthy.
I tend to agree with you all that the seals are aged for sure. I will find out hopefully this weekend what exactly is leaking and just hope its not a bearing.
Old 04-05-2024, 05:36 AM #6
Real Name: Mark
Real Name: Mark
Filthy one thing shiny stuff on drain plug magnet another. What it look like?
Old 04-05-2024, 11:22 AM #7
vegask vegask is offline
vegask will become famous soon enough
If its just coming from the front output, there is no need to pull the case. Just remove the front drive line, remove the flange, pull the old seal, replace...
Probably a good idea to drain the case before pulling the seal.
I had to do the rear output on mine years ago, removing the flange bolt was probably the hardest part.
SAS 97 4runner / Bone stock 2005 4runner / aka "Kurtfab"
vegask is offline   Reply With QuoteReply With Quote
Old 04-06-2024, 09:28 AM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The only problem is, the guy said it was coming from the "input" so I assumed he was seeing gear oil leaking from the bottom area of the mating of the transmission and transfer case.
Old 04-07-2024, 04:39 PM #9
My bad, mis read the first post.
You could ban-aid it with this stuff, it worked well fixing a small leak on my crawl box.
Amazon.com
kit , leaking , parts , rebuild , transfer
Transfer case leaking EEEliminator 5th gen T4Rs 7 03-31-2019 10:35 AM
transfer case is leaking jediwebdude 4th Gen T4Rs 16 10-16-2015 11:23 PM
Transfer case leaking, but not sure from where WallyWest 3rd gen T4Rs 7 07-06-2015 10:15 PM
transfer case leaking yotababs86 Problems & Warranty Issues 0 03-25-2012 06:20 PM
Transfer Case Leaking DesertDune4x4 3rd gen T4Rs 7 11-30-2009 02:46 PM
