Old 04-08-2024, 11:32 AM #1
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Brake Squeal After New Pads
Hello all,
My brakes have been squeaking for a couple months, and I didn't think it was my front pads since I just replaced them a couple years ago. So I took my 4R to a shop to do the rear drums (also had an axle seal leak), still squealing. So I went to replace the front pads (Akibonos) and was surprised to see my old pads still had probably half their life left. Whatever, I just replaced them anyway.
However, I still have a break squeal coming to a stop. Didn't replace or resurface my rotors or anything. So my question is, what else could be squealing? Nothing looked damaged or like it was rubbing when I swapped my front pads, so I'm kinda stumped for now.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 04-08-2024, 12:32 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It actually could just be the brake pads themselves. Are the calipers free the pistons moving freely? Brake pads can slide freely? As these other things can be causing issues too. Are you feeling any heat from the front brakes after a drive? These can also cause a squeal.
I had a set of pads squealing only when I backed up. Upon investigation, I found a piston on the caliper was seized. Causing this entire issue. So might be worth going over the calipers with a fine tooth comb and check everything out.
Also maybe best to be sure the 2 springs are in place. One will keep the pads from chattering. The other clips over the 2 pins to hold tension on them. As these are just some thoughts as to why your breaks maybe squeling on you. :-)
Old 04-08-2024, 12:33 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Slightly bent rockshield maybe? (though that would make noise all the time not just braking). Sometimes a good high pressure air blowout helps get lodged debris that maybe causing noise helps.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 04-08-2024, 12:52 PM #4
prybar's Avatar
prybar's Avatar
Pistons not seized, didn't have any trouble backing them out to get the new pads in. I did grease the pads so they should be able to slide freely too. I haven't checked for heat after a drive, wouldn't they be hot pretty much any time you drive? Springs/retainers are all in place and everything was looking good yesterday. I guess I'll bust out my fine tooth comb to check again tonight. Thanks!
'99 Limited, 260k
Old 04-08-2024, 12:54 PM #5
prybar's Avatar
prybar's Avatar
I agree that the rockshield should squeal all the time if that was the case, but I'll give it a peek this evening. I'll use some more brake cleaner then blast it with air and see if that does anything. Thanks for the suggestions!
'99 Limited, 260k
Old 04-08-2024, 01:29 PM #6
Krup235 Krup235 is offline
Krup235 is on a distinguished road
Sounds like you got a glaze on your pads. Did you do a good burn in when you installed them?
Krup235 is offline   Reply With QuoteReply With Quote
Old 04-08-2024, 03:02 PM #7
prybar's Avatar
prybar's Avatar
Yes, I did. I'll do it again on my way home today
'99 Limited, 260k
Old 04-09-2024, 07:19 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It might just be the pads. OEM pads come with a 2-Piece Anti-Squeal shim set-up. I've never had OEM pads and shims squeal. Parts are listed in the video description.
front , pads , replaced , squeal , squealing
Tundra brake caliper leaked brake fluid all over pads, replace or clean pads? Srt4runner 3rd gen T4Rs 8 10-30-2015 12:42 AM
rear squeal - semi metallic brake pads - low speeds shahsmerdis 4th Gen T4Rs 10 09-02-2015 10:09 AM
Brake Drag/Squeal After New Pads and Rotors? bluemarlin04 4th Gen T4Rs 2 03-12-2013 06:47 PM
brake pads. my brake pads r squeeling. want to know if Thermo quiet will work spartacus 3rd gen T4Rs 4 04-21-2012 08:00 AM
New brake squeal help please.... 2K34R Problems & Warranty Issues 18 06-08-2008 05:46 PM
