Old 04-07-2024, 11:55 AM #1
Forrest931 Forrest931 is offline
Real Name: Forrest
Forrest931 is on a distinguished road
Real Name: Forrest
Soft brake pedal 3rd gen t4r
Hey all,
I’ve been chasing down a very soft brake pedal for as long as I’ve Owen’s my 96 limited t4r. To give a List of the things I have done to try and tackle the issue I have done
Tundra brake calipers pads and rotors
New oem rebuilt brake booster
New oem brake master cylinder
I’ve done a high pressure bleed a couple times
If anyone could shed some light onto my parts cannon problem that would be great, I’m thinking it’s possible there is air in my abs module. thanks t4r
Forrest931 is offline   Reply With QuoteReply With Quote
Old 04-07-2024, 02:55 PM #2
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
When you doing the bleeding, did you do the rear brakes? You don't mention the rear set of brakes at all.
Did you bleed the LSPV last of all? They're known for collecting dirt/crud, and air.
Just checking. After all, the rear brakes are bled first, and the LSPV last. Any of them can have air in them, after all. Heck, for all I know, you may have a rear axle seal leak, and the the rear shoes need replacing. I had that, and once I got them replaced (I hate drum brakes!) it was night and day. The pedal firmed up, and the whole brake system felt like a new one.
Anywho, good luck to you!
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
Old 04-07-2024, 04:14 PM #3
There is no LSPV on ABS equipped 3rd gens, only on non-ABS models.
The bleed procedure for '96-'00 4Runners is very specific:
First, note the unusual master cylinder procedure - this sets the front/rear fluid balance system (extra thing on the side of the master cylinder) in the correct location for operation. If this is not done correctly, this will cause poor brake pedal feel and poor brake performance.
THEN, you need to bleed in the correct order or it will mess that system up.
THEN, it is very easy to get air trapped in the ABS system, and activating the ABS actuators requires specific (and long out of production) SSTs from Toyota.
After you get the pedal OK with the above procedure, find some dirt and get the ABS system to activate, then bleed again. It might take a few tries, but then you'll have good (for a '90's SUV) brakes.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-10-2024, 05:49 PM #4
Jaydid Jaydid is offline
Jaydid is on a distinguished road
Thanks for posting that procedure. I hadnt seen this but I am about to have the brakes done on all 4 corners
Jaydid is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 06:17 PM #5
Fas7Eddi3 Fas7Eddi3 is online now
Fas7Eddi3 is on a distinguished road
Typically a soft pedal means air is somewhere in the system.
Fas7Eddi3 is online now   Reply With QuoteReply With Quote
Old 04-13-2024, 09:53 AM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by Jaydid View Post
...am about to have the brakes done on all 4 corners
Besides the obvious pads-shoes does this mean a complete drain-fill of brake fluid also? That made mine good as new - firmish.
Old 04-15-2024, 05:16 PM #7
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
You could also get 4 tires up in the air and use 4x4 in drive to activate abs
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 04-20-2024, 07:42 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes +1 soft means air or maladjusted rear brake drums. I done two different tundra caliper upgrades and it can be tough at times to get the air all out. Especially if you run the brake system out of fluid. Its best to keep the fluid in the system and just cap off the lines when changing the calipers..
brake , i’ve , oem , soft , t4r
Soft brake pedal mwrohde 3rd gen T4Rs 60 08-05-2022 12:29 AM
soft brake pedal Bacon 4th Gen T4Rs 6 04-06-2015 10:00 AM
soft brake pedal- low RPM's willyt4r Classic T4Rs 2 10-05-2011 11:15 PM
Soft Brake Pedal 93 4Runner Sammer Classic T4Rs 1 06-20-2006 11:56 PM
