Old 04-11-2024, 06:44 PM #1
Deej101 Deej101 is offline
Deej101 is on a distinguished road
Well this doesn't look right (driver door wiring)
2001 SR5. Been trying to chase down elec gremlin forever in this car. Finally got around to pulling all the tape off the driver door wires and found what you see below.
Going out on a limb here, but that does *not* look stock to me
Might I have *finally* found the source of my problems???
Well this doesn't look right (driver door wiring)-pxl_20240411_211056821~2-jpg  Well this doesn't look right (driver door wiring)-pxl_20240411_213351381~2-jpg  Well this doesn't look right (driver door wiring)-pxl_20240411_213121844~2-jpg
Deej101 is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 01:25 PM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I'd say that good cause for gremlin's W-B is always a ground doesn't serve it's purpose isolated.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 04-12-2024, 02:05 PM #3
WTAF? So all the ground wires were bundled together and stuffed into a plastic sleeve....? Why?
I hope this finally explains everything so I can start putting back everything I tore out to track this down!
Old 04-12-2024, 04:40 PM #4
Real Name: Mark
Real Name: Mark
"It happened after removing the security system." OP in other thread.
Let me guess aftermarket security system Bit cha in da azz, best teaching simulator there is.
The spiderweb of control wiring got a love it, jigsaw puzzle at it's finest. 576 ring a bell.
And the yellow junction is questionable.
Old 04-12-2024, 05:37 PM #5
Yes, of course. But also aftermarket DIY audio system (now removed).
I think it may have just been an issue of poor insulation, because symptoms always got worse during wet weather.
And maybe the bundling of ground wires in itself isn't horrible (is it?) and maybe sticking them in a plastic tube so nothing can touch them isn't awful, but it just seems...weird. I think the yellow wire might actually be the issue though.
Old 04-12-2024, 06:09 PM #6
armabill armabill is offline
armabill is on a distinguished road
If the plastic tube gets condensation inside it, it may be an issue.
armabill is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 07:46 PM #7
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I think the yellow wire with black strip splice is factory. Where do those wires run to? Do you have a zoomed out picture?
Here's the wiring diagram for that. You can see there's a wire splice there.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 08:26 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those grounds are most likely factory. White Black is ground in Japan. Yes they are all bundled together in wiring harness and dumped to a eyelet connector to the chassis for ground a points.
The yellow black is a ground as well and that is factory spliced. Feel all the wires in the booted area between the door and the jam. This is where the wires always break split and short in the wiring.
That all really looks normal to me as well. :-(
Old 04-12-2024, 09:14 PM #9
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Can't speak for the white/black but the yellow/black is definitely factory, I ran into the same splice somewhere around the dash a few months ago. I remember being surprised by it as it struck me as kind chintzy
Old 04-14-2024, 05:11 PM #10
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Looks factory to me. They are called junction points usually indicated by a 🛑 symbol. It's where a ton of common wires are spliced together ie grounds, or splices. Looks normal to me. Interior wiring usually doesn't have any kind of water protection (unsealed connectors).
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
door , driver , found , limb , stock
Key in driver door unlocks only driver door, but key in passenger door unlocks SOLVED Deej101 3rd gen T4Rs 3 09-12-2021 08:15 PM
[eBay] 1998 4Runner Driver Door Wiring Harness - Saskatchewan Ellis Precision For Sale: T4R Items 0 08-07-2017 03:42 PM
Driver's side door unlock button doesn't work HedgehogOutdoors Engines / Suspension / Wheels / Tires / Audio / Accessories 7 04-20-2016 10:09 PM
Driver side door lock doesn't work and trans cooler install questions Golfinz 3rd gen T4Rs 10 02-11-2013 07:39 PM
Car and Driver 40K Offroad SUV Shootout... 4R doesn't win... bradj 5th gen T4Rs 45 10-13-2010 10:36 PM
