Originally Posted by phattyduck
Most shops that do a particular transmission regularly will cut the input shaft off a broken trans to use. You'll have to be careful with the plastic too since there is some extra play there. When you put it back together have a *very* light film of grease on the input shaft (like, apply then wipe it off fairly well) and a bit of grease on the dowel pins too to help everything come together.
What do you mean by "be very careful" with the plastic tool? What am I trying to avoid from happening? I haven't studied the installation process in detail yet, maybe it will be obvious when I do.
I have also used extra bellhousing bolts with the head cut off (and a slot cut in place of the head to allow removal) as alignment dowels to help too. You may also have to rotate the trans output shaft (with it in gear) slightly to get the input splines to line up with the clutch.
Do you install the cut bolts first and use them as extra dowels, or screw them in once you have it close just to tweak the final alignment? I like the idea but might try it once without just to see if I get lucky.
I don't think I'm going to get lucky on the flywheel. I'm no expert but to me it looks like new flywheel time.
