Old 04-26-2024, 03:44 PM #1
dogbreath650's Avatar
dogbreath650 dogbreath650 is offline
dogbreath650 is on a distinguished road
DENSO MAF sensor discontinued for 98T4R
I've tried a couple OEM parts places and the say the MAF sensor for my 98 Limited has been discontinued, that I'd have to source it after market. Need some advice on which might be a reliable after market brand. Thanks...
98 T4R Limited, auto, locker, G1 supercharger
dogbreath650 is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 08:05 PM #2
maxthebird maxthebird is offline
maxthebird is on a distinguished road
I feel your pain since I have the same year and expect to need one eventually too. From what I've read, I would not trust any after market MAF. Better to go the used OEM route on eBay for about $100. Most sellers will accept returns if it doesn't work. If someone comes up with an aftermarket one that works, I'd be interested.
maxthebird is offline   Reply With QuoteReply With Quote
Old 04-27-2024, 04:00 AM #3
19963.4lsr5 19963.4lsr5 is online now
If you have the big round sensor there are threads to convert over to the newer style sensor.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 04-27-2024, 06:22 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Is this what you're looking for?
1998 Toyota 4Runner Parts - ToyotaPartsDeal.com
2004 Limited V8
Old 04-27-2024, 11:31 AM #5
no, this is what I'm after
22250-20020 Genuine Toyota Meter Assy, Intake Air Flow)
Old 04-27-2024, 12:23 PM #6
geezerr54 geezerr54 is offline
geezerr54 is on a distinguished road
PM sent
geezerr54 is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 08:59 AM #7
Real Name: Skip
Real Name: Skip
Unless I'm mistaken, the part you posted is the complete assembly that has the MAF sensor inside of it, the part I posted is the actual MAF sensor that fits inside the complete assembly, unless there's a problem with the complete assembly you should only have to replace the MAF sensor not the entire assembly.
2004 Limited V8
Old 04-28-2024, 10:36 AM #8
His 98 uses this type of older MAF sensor.
Old 04-29-2024, 02:51 AM #9
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ is on a distinguished road
gh25_'s Avatar
This topic has been discussed before in some other fourms and I've read all of them related to this. I also have a 1998 with 203K on it and will probably need to replace mine eventually too. The consensus IMO for this is to do the 2000+ MAF & airbox swap along with the MAF connector re-pin. There are some great detailed fourms on here about it. If you don't know the 2000+ style maf are separate from the tube. There is two screws holding them into the tube thats on the air box. If you get a 2000+ airbox and the maf + the wiring re pin that would be your solution to this. The newer style maf sensor that the 2000+ uses is not discontinued or anything and is still widely availble. You can get a brand new one on RockAuto for $85. You have a choice of either sourcing a newer style airbox from a junkyard car / on ebay or this company called Brock makes a replacement airbox for 1st gen tacomas but it's the same exact everything as our 4runner airboxes. Like one of the guys on here already said I wouldn't trust any aftermarket brand for the MAF sensor, seeing as how it's such a crucial part to how your truck runs. With this swap you go to a much easier replaceable MAF that's cheaper and you stick with the OEM manufacture (Denso). Hope this helped. Going to adda couple links to the fourms and other stuff so you can see for yourself
Amazon.com
More Information for DENSO 1976020
97 maf to 99 conversion without air box swap!
'97 4runner to '99+ 4runner airbox/MAF conversion
gh25_ is offline   Reply With QuoteReply With Quote
Old 04-29-2024, 09:06 AM #10
gh25 thanks for the detailed response! I think I'll have to go with your fix as I don't see any better alternative. I've been looking for another solution because I've never repinned anything, guess it's time to learn...
Old 04-29-2024, 02:53 PM #11
gh25_'s Avatar
gh25_'s Avatar
Of course! Glad I could help. And yeah honestly I don't think there is a better option lol. The only option is to try and get a used one but then your right back in square one with the old style MAF. With the updated airbox replacing the maf is actually even easier since it's just two little screws instead of having to take off the air tube. Honestly kinda unfortunate toyota designed it that way but oh well at least theres a fix. And BTW the re-pinning is super easy. All your doing basically is removing the pins from the plastic connector housing and changing them to a different location / hole in the connector. No soldering or anything. Just make sure to read the fourm about it or else it can be fustrating lol. I recently did a steering wheel swap in mine and after figuring out how the wires come out of the connectors it's easy now. There will be a bigger clip that holds the all pins in that you have to get out with a pick or really small screw driver and then the pins are still held in by little tabs on the connector so you just have to use your really small screw driver or pick again and tug on the wire your taking out and depress the little tab thing holding it in and the pins will come out.
@habenaro who is also on here has a great post on yotatech fourms with pictures of everything for the re-pin and showing taking out the pins. You can do it! Start at post #3327
habanero's 1996 4Runner Build-Up Thread - Page 167 - YotaTech Forums
Here's also a video a guy on youtube made who also did the re-pin.
1996 thru 1998 toyota 4runner cold air intake update + MAF repin - YouTube
Old 04-29-2024, 04:19 PM #12
The Amazon link I posted is a current link. I’m pretty sure They made the sensor for Toyota.
The newer one would be the way to go as long as you can source the parts.
Old 04-29-2024, 07:00 PM #13
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is what I would do as long as the MAF is available. You would know pretty much immediately if the Aftermarket MAF is bad. I luckily have a few spare used ones I grabbed at yards before they were gone.
All mine so far are working so far and I have 2 1997 with 257K and a 1998 with 290K with the original MAF in them. I just every few years clean them with the MAF sensor cleaning solution. :-)
brillo_76 is online now   Reply With QuoteReply With Quote
denso , discontinued , maf , market , sensor
Denso o2 Sensor centxrunner 3rd gen T4Rs 112 10-17-2018 05:26 PM
Denso O2 sensor blairvt 3rd gen T4Rs 18 10-14-2018 12:55 PM
Denso o2 sensor sigley0527 3rd gen T4Rs 3 06-17-2013 09:48 AM
O2 sensor Denso vs NGK neilr 3rd gen T4Rs 1 05-26-2013 11:24 AM
F/S: Denso O2 Sensor Rescue84 Classifieds - buy & sell (no commercial ads please) 0 06-28-2007 10:00 PM
