Old 07-28-2024, 03:35 PM #16
igetfortunota igetfortunota is offline
igetfortunota is on a distinguished road
Originally Posted by phattyduck View Post
Glad to hear it!
You can get the spray cans of Fluid Film from NAPA locally - but you won't find anyone that will do it for you outside of the rust belt. I keep a can of Fluid Film around for bare metal tools (drill press, etc.) to keep them rust free out in the garage. I'm not sure how many cans it would take to treat the truck yourself though...
My Cali truck never sees winter BUT as lifetimer in the rust belt, I can tell you without a doubt, fluid film has my business for life.
I read all the reviews, watched the entire internet, chose FF and frankly I was shocked at how well it performs. We purchased the kit that has the sprayer and hoses/nozzles(you could piece this yourself if you wish) and spent a good amount of time on everyone's vehicle(silverados and tacomas) that sees winter. The stuff absolutely can make it through a PA winter, and its absolutely worth it. If you do the application adequately/thoroughly you literally can't tell that the vehicle sees any winter.
Like Charlie said, even the lube properties of it are awesome, I've used it in can form for for latches, hinges, all little fiddly stuff and it performs as good as just about any standard maintenance canned lube/grease etc.
One thing to note: obviously its considered a consumable type application. The important thing for me on it is that if its a front facing part or section(arms, spindle, skid plate, frame/x-member, you get the point), you will probably want to do a slightly thicker application, a second pass of sorts. Sometimes the regular driving wears it away over the entirety of 7-8 months of winter.
Again though, its enough that after 1 season it was an 'oh we should put thicker application on' - problem solved. And for reference to the compulsive folks like myself, there wasn't rust developing at the end of the season, you could just tell the salty road bring just wore it down a bit compared to the completely untouched sections.
My suggestion is to hit it around Halloween and you can easily make it through March/April.
01 SR5- sold
99 SR5 - manual box: desert dry, always garaged in winter.
I can restore your scratched gauge cluster plastic
igetfortunota is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 06:40 PM #17
TracyNorton's Avatar
TracyNorton TracyNorton is offline
TracyNorton is on a distinguished road
Out here in So Cal...Big Bear in particular...they are now using brine on the roads up to BB when it snows. (Cal Trans acknowledges this on their website)
I had surface rust EVERYWHERE in a couple of days of driving around up there last winter.
I douched the entire underside w/ Berkbile Salt cutter....then coated all the rust w/ Eastwood Rust Converter after it dried. Now no rust.
This sucks, but it is what it is....now I wash my truck every time I come down from there in the winter (my daughter lives up there and has a 2nd gen that has same surface rust prob).
I'm considering a spray on Lanolin product, or the Cosmoline as mentioned.
98 SR5 4x4 5sp w/ fact rear locker
Ostentatious TVS1320 (65mm Pulley)
ARB & 6112s business up front, CBI DSG & LC 862s/Tokicos party in the back
Lots of So African electrics strewn thruout. Everything else Aussie made.
TracyNorton is offline   Reply With QuoteReply With Quote
east , rot , rust , sending , surface
Is this surface rust or something worse? Ludachrisx8 5th gen T4Rs 4 02-12-2019 11:31 PM
Surface Rust or?? Buck208 3rd gen T4Rs 4 11-26-2015 06:21 PM
The fj springs I am looking at have a little surface rust clemsonxplorer 4th Gen T4Rs 1 05-08-2010 08:23 PM
surface rust on canopy papageorge Classic T4Rs 2 04-03-2007 06:07 PM
surface rust? imprttuner88 4th Gen T4Rs 10 09-24-2006 10:25 PM
