Old 07-02-2008, 09:43 PM #1
haddix's Avatar
haddix haddix is offline
haddix is on a distinguished road
haddix's Avatar
led lights for stereo..
Is there any way I can malke all the lights in my 4runner that are green to become white ?
2007 FJ Cruiser
haddix is offline   Reply With QuoteReply With Quote
Old 07-03-2008, 12:00 AM #2
Fo_SheeZy's Avatar
Fo_SheeZy Fo_SheeZy is offline
Real Name: Brian
Fo_SheeZy is on a distinguished road
Fo_SheeZy's Avatar
Real Name: Brian
Yup.. try this thread:
http://www.yotatech.com/f2/gauge-das...ghting-117226/
2008 Black Urban 4Runner (SOLD)
Check out my 2014 Trail Edition Premium build thread
Fo_SheeZy is offline   Reply With QuoteReply With Quote
Old 07-03-2008, 01:33 AM #3
O.State4runner O.State4runner is offline
O.State4runner is an unknown quantity at this point
follow that thread! i used that and other threads from searching on yotatech.com. i've got all blue LED in the guage cluster, a/c control, auto shifter, key ring, cig lighter, anything with a bulb. two website to buy from that i recomend:
www.superbrightleds.com
www.autoalumination.com
i've ordered a crap ton from superbrightleds. but autoalumination seems to be a little more higher-end LEDS but superbrightleds has a a little better prices.
96 'street' 4Runner SR5
http://i298.photobucket.com/albums/m...er/online1.jpg
- evergreen pearl paint
- Clear corners & bumper lights w/white LED corner & amber LED bumper
- Clifford alarm, remote start, auto rollup windows
- Kenwood Excelon VZ970
- Kenwood satellite tv
- Infinity Kappas for door speakers
- 12" MTX sub with Kicker amp w/ dynamat trunk
- Flowmaster 40Delta w/ tip
- Silverstar Ultras
- custom grille mod
- converted gauges/ac control/key ring/shifter/domelights to blue LEDs
- cobra radar detector
- airaid MIT w/ dropin K&N filter
- 4" deckplate
O.State4runner is offline   Reply With QuoteReply With Quote
Old 07-03-2008, 02:43 AM #4
Fo_SheeZy's Avatar
Real Name: Brian
Fo_SheeZy's Avatar
Real Name: Brian
Don't forget www.v-leds.com
Recently I have been ordering from there, You get two led's in each purchase where autolumination you only got one.
Old 07-03-2008, 03:30 AM #5
The Dude's Avatar
The Dude The Dude is offline
The Dude is an unknown quantity at this point
The Dude's Avatar
Are you talking about the toyota factory stereo?
Was wondering the same thing too....I have a factory stereo in mine as well, hooked up to a JL audio clean sweep, and I wanted to see if i could change out the LED's to white bulbs.... so I took off the face, and it turns out that they're tiny green LED's soldered onto the circuit board. I'm sure it can be done, but it's not a plug n play simple job.
I'm planning to go with white LED's, but because of the green lights on the stereo, I'm probably going to leave all my HVAC controls green, and just change out the lights on the guage cluster.
The Dude is offline   Reply With QuoteReply With Quote
Old 07-03-2008, 03:34 AM #6
The Dude's Avatar
The Dude's Avatar
If you do have a factory stereo in yours.....a simpler solution would be to get a new head unit to match your new set of LEDs. It'll sound better and look better too.
I just have a preference for factory stereos over aftermarket, so i opted for the JL clean sweep.
Old 07-03-2008, 08:35 AM #7
004Gunner's Avatar
004Gunner 004Gunner is offline
Registered User
004Gunner is on a distinguished road
Registered User
004Gunner's Avatar
FYI: The lights in the door lock switches are also tiny green LEDs soldered into the board. Also the white LEDs are very difficult to match up because of differences in their lighting temperature, some have a cool appearance and others have a warm appearance. I switched back to mostly factory lighting after I found that nothing matched up and some areas had hot spots.
004Gunner is offline   Reply With QuoteReply With Quote
Old 07-03-2008, 11:25 AM #8
Fo_SheeZy's Avatar
Real Name: Brian
Fo_SheeZy's Avatar
Real Name: Brian
Old 07-03-2008, 11:43 AM #9
greyghost4x4's Avatar
greyghost4x4 greyghost4x4 is offline
greyghost4x4 is an unknown quantity at this point
Fo_SheeZy, when are you goning to get clear corners for that new urban runner? lol
Evan
I can't afford a signature, I have a girl friend.
greyghost4x4 is offline   Reply With QuoteReply With Quote
Old 07-04-2008, 01:37 AM #10
Fo_SheeZy's Avatar
Real Name: Brian
Fo_SheeZy's Avatar
Real Name: Brian
LOL man, I dunno. I'd have to bake my headlights in the oven to get them apart and I dunno if I'm up to doing that... lol
Old 04-30-2024, 02:06 AM #11
Pchavarria Pchavarria is offline
Pchavarria is on a distinguished road
Tried swapping out a lot of lights all at once (instrument cluster, PRNDL, Climate control) didn’t see this mentioned anywhere but I learned that some of the bulbs come out of the little plastic housing (in the instrument cluster and PRNDL) but some do not (pretty much everything in the media trim and climate control)
Popped a couple in the climate control thinking they were just tough to pull out.
Also learned that the climate control won’t function without these plastic inserts. So had to dissemble again and put them in as place holders until the new bulbs come in.
Oops. Live and learn hahaha
So, I actually ordered replacements and left the broken bulbs in the climate control for now so that my AC functions. Anyone have any clue if this might be a fire hazard? Rather pull them out and go without an AC for now if that’s the case.
Pchavarria is offline   Reply With QuoteReply With Quote
LED Tail lights LBeard87 4th Gen T4Rs 13 09-20-2012 08:35 AM
LED lights: Turn Signals and Corners 4runninRob 3rd gen T4Rs 18 02-04-2010 12:06 AM
LED signal lights Tory Engines / Suspension / Wheels / Tires / Audio / Accessories 5 08-09-2007 01:55 AM
LED All Interior Lights TRDSilverBulitt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-05-2007 09:08 AM
LED Tail Lights installed cdoyle Engines / Suspension / Wheels / Tires / Audio / Accessories 18 12-28-2005 11:10 PM
