Changing An A/F Sensor?
fivetensh
Hey everyone, new to 4Runner.
I'm a Honda guy, so I'm unfamiliar with Toyotas. This is for my ladie's 4Runner.
2000 4Runner SR5
I used an OB2 reader to pull the following codes:
P1133
P1135
P1130
A couple were pending codes, the others actually tripped codes. Usually around 50-60MPH.
Anyway, cleared the codes, CEL went off, and then came back on later that night.
I figured it was an 02 sensor, checked online, the only thing I could find was 02 sensor, position 1 bank 1. [?] I have no idea what that means.
Fast forward to today, I went down to Toyota. Service guy took my VIN# and the codes I pulled, and I walked out with an Air/Fuel sensor.
Part#:
89467-35011
SENSOR,
AIR FUEL RAT
Question is:
Where does this sensor go? Looks simple enough, 2 bolts on the flange and then a plug.
Thanks in Advance.
-Mace
did the part look like this?
from what i have read and may know, 4runners have 2 or 4 O2 sensors, and cali cars have 4 because of smog rules, i am not quite sure what they mean by 1 or bank 1,
i think if you replace our o2 sensor you should be fine, and make sure its exactly the right one, because there are 2 diffrent o2 sensors on california cars
