Old 01-20-2009, 08:36 PM #1
BB6-213 BB6-213 is offline
BB6-213 is an unknown quantity at this point
3" Suspension lift- What size Body lift for 35x12.50's?
Hi, I am looking at buying a 96-02 4runner for a daily driver and occasional mild off-roading, and I am planning on using the ToyTec COilovers up front 0-3.5", with 3" coils on the rear, and I was wondering, what size body lift would I need to clear some 35x12.50's as I have a set of MT Baja ATZ 17's that I would like to use. I would like to do the minimum lift to keep it reliable and fit those tires without major rubbing, so any help would be greatley appreciated, and BTW I searched and searched, but couldn't find anything. Thanks.
BB6-213 is offline   Reply With QuoteReply With Quote
Old 01-20-2009, 09:18 PM #2
haddix's Avatar
haddix haddix is offline
haddix is on a distinguished road
haddix's Avatar
Maybe like a 2 inch body lift. Im guessing but I think thats right.
2007 FJ Cruiser
haddix is offline   Reply With QuoteReply With Quote
Old 01-20-2009, 09:32 PM #3
If it is only a 2" that would be great!
Old 01-20-2009, 09:36 PM #4
beallen21's Avatar
beallen21 beallen21 is offline
beallen21 is an unknown quantity at this point
beallen21's Avatar
you'll for sure have to trim a few things if you dont want them to rub
98 Frunner, Daystar 2.5inch lift, 275/55r20's Cooper Zeon LTZ, two 12's amp and all that noise...thinkin about a small body lift
beallen21 is offline   Reply With QuoteReply With Quote
Old 01-20-2009, 10:07 PM #5
Clemsonfan15's Avatar
Clemsonfan15 Clemsonfan15 is offline
Clemsonfan15 will become famous soon enough
I think you'll have to extend a bunch of stuff if you go with a 2" body lift.
Check out my garage.
Clemsonfan15 is offline   Reply With QuoteReply With Quote
Old 01-20-2009, 10:14 PM #6
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Go with a suspension lift, much better... gives form and function.
Body lifts are ultimately for looks... and if you get one too big, you'll have to extend shit. Really all they're for is to fit bigger shit and that's just stupid.
I mean if you might as well have the functionality.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 01-20-2009, 11:46 PM #7
beallen21's Avatar
beallen21's Avatar
you aren't going to get enough suspension lift by itself to house the 35's unless you do some MAJOR fabrication
Old 01-21-2009, 11:53 AM #8
01t4rnr's Avatar
01t4rnr 01t4rnr is offline
01t4rnr is on a distinguished road
01t4rnr's Avatar
yep and alot of guys, not all but most, say its not worth it to go up from 33's to 35's unless youre mostly offroad and even then its a lot of making things work to run them. Hell id like to have a set of 35's under mine but then you need to regear, etc. etc.
** a 2" body lift would run 35's if you can find one
2001 4 Runner 4wd SR5 v6 auto. TRD Tundra coils,adj. Bilstein 5100's, 8 wrap LC coils, 15% tint, Hella 500's, Skyjacker Nitros, 285/75/16 Mud Dawgs, 16x10 rims, B&M 70268
01t4rnr is offline   Reply With QuoteReply With Quote
Old 11-23-2010, 06:45 PM #9
Spish Spish is offline
Spish is on a distinguished road
From Steve at SS
suspensionFAQ : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
If you don't stand behind our troops... feel free to stand in front of them!
97 Limited
- 17" Tundras/285 Duratracs, Spidertrax, Toytec Ultimate lift/ Toytec 1" body lift/ SS adj Panhard bar, Deckplate, 4X innovations DOM sliders, Some stickers for extra power
Spish is offline   Reply With QuoteReply With Quote
Old 11-23-2010, 09:43 PM #10
steezemcqueen's Avatar
steezemcqueen steezemcqueen is offline
Moderator
Real Name: Dylan
steezemcqueen will become famous soon enough steezemcqueen will become famous soon enough
Moderator
Real Name: Dylan
no extensions needed for the 2 inch other than the steering shaft spacer which is also needed on the 1 inch
Body Lift for 96-02 4-Runner - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
steezemcqueen is offline   Reply With QuoteReply With Quote
Old 11-23-2010, 10:18 PM #11
rusm rusm is offline
rusm is on a distinguished road
To get 35's to fit offroad is going to take some work, bodylift or just cutting. I spent Saturday trimming the front fenders and pounding in the pinchweld in an attempt to get them to fit without cutting. Not going to happen.
rusm is offline   Reply With QuoteReply With Quote
Pics of suspension and body lift!!! 99Yotarunner 3rd gen T4Rs 26 02-19-2010 11:00 AM
Daystar Lift on sketchy suspension 4runr30 4th Gen T4Rs 4 09-09-2009 09:53 PM
Suspension Lift 916RunnaStunna 3rd gen T4Rs 4 07-17-2009 02:14 PM
Which suspension lift and tires?? StormTrooper 4th Gen T4Rs 46 05-30-2009 04:06 PM
one inch body lift escoastrider72 3rd gen T4Rs 2 04-03-2006 01:50 AM
