Old 01-25-2009, 12:31 AM #1
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Climate Control Module question
I have a 99, my module is the basic of the basic. I have the two sliders and the two knobs.
My question is, my bud has an 01 and he has the 2 button, 3 knob control module. I have found these for sale before and I like the look better. Do they just plug right in with the same plugs? I am sure he would not like it if I pulled his center console/cluster apart, even though it literally is only 3 pieces.
How about a limited module with the screen and all?
Thanks!
Climate Control Module question-climate-jpg
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 01-25-2009, 01:09 AM #2
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
Limited would probably be a PITA. The limited has auto climate control, which requires photo cells, and temp sensors and servo motors that the basic climate control doesn't need.
as far as the early vs late model, i can't help there .... you could always look up the wire pinout on the TIS site.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 01-27-2009, 05:36 PM #3
GamecockRooster's Avatar
GamecockRooster GamecockRooster is offline
GamecockRooster is on a distinguished road
For what it's worth, I would encourage you not to get the digital climate control. Not that you probably want to deal with the additional expense of the add-ons necessary to pull this off, but that's the one thing I do not like about my 99 Limited. If I could replace it with a standard switch system I would. I've had to replace the digital control head and I searched for about two months before I found something that wasn't $800.
'99 4Runner Limited 4wd
GamecockRooster is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 08:06 PM #4
michael833's Avatar
michael833 michael833 is offline
Real Name: Michael Catarineau
michael833 is on a distinguished road
michael833's Avatar
What did you end up doing COB? I've been wondering the same thing lately.
michael833 is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 08:31 PM #5
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
Yeah you need the computer and extra sensors for the digital unit , not plug and play for sure and very.expensive .
I have the digital unit from canada that reads in c, if I want it to read in f, I have to swap everything out, 1k or so for the job just for computer and.sensors .....
Also if your bent on doing this do the led mod from the get go , it will save.you.some pain in the long run
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
theizzardking is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 09:07 PM #6
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Thanks!
Do you have a picture of the back of this unit?
Maybe the plugs are the same.
as for your application, your sliders are connected directly to cables while the above picture is electrical.
Singtoe is offline   Reply With QuoteReply With Quote
Old 01-18-2011, 09:53 PM #7
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr will become famous soon enough
quicksilvr's Avatar
I'm going to say no, it will not work very easily. For two reasons: The fresh air/recirculate control changes from a slider to a knob....so the controls behind the HVAC head are different for that. Second, the A/C button moves from it's classic position to a completely different place, and a different style button. The old style A/C button is pretty unique and self contained....that new style one is quite a bit different.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 01-19-2011, 10:10 PM #8
Moderator
Real Name: James
Moderator
Real Name: James
Well, I just kept the one I have. No sense in changing it really... not for the 01-02 module which is very similar. The connections are all off and it would just be a pain in the ass for the same thing.
The Limited module would have been free for me, I had a Limited traded in at my work and I was gonna do the ol' switcheroo. Didn't do it, though.
The rest of you, thanks, but I posted this thread 2 years ago
Climate Control Swap 01sr54x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-06-2009 07:54 PM
digital climate control question.... SilverBullet01 3rd gen T4Rs 2 03-26-2009 07:38 PM
auto climate control question dave4242 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 12-22-2003 07:40 AM
climate control question dave4242 Problems & Warranty Issues 2 12-11-2003 10:11 PM
Climate control sceptre Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-26-2003 12:04 PM
