In-Dash Lights?
CrazyDragon408
hi all, one of my lights in my dash board (left-side where temp gage) is out. Does anyone have any input how to replace this bulb? i would like to have all my lights working. :pimp:
Thanks for your input......:guitar3:
It's been a while since I've played around in the instrument cluster, but if I recall, you unscrew the black trim then you will see where the screws holding the cluster down. Remove them, unplug the cluster and then flip it to the backside and you will see 4 or so number of caps which actually house the bulbs. You can also pull the condoms off these bulbs to make them the original color of the lightbulb or install diff colored bulbs.
Hope that helps, enjoy :)
I dreaded this because mine went out too. But guess what its really easy!!;):
Remove the lower kick panel, then the trim around the key. Then only 4 screws hold the gauge cluster in. There are 3 connectors on the back. One you get it out just replace the appropriate bulb. I would recommend replacing all 4 of the large bulbs as it would suck for them to go out after you put it back together. Also, i removed the plastic faceplate and buffed/polished all the crap that had accumulated over the years off of it. Now its so clear you cant even see the plastic cover on it. Best mod ive done. But be sure not to mess with the needles, they are delicate.
