Old 08-10-2024, 01:04 PM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
1999 4WD rear driveshaft replacement Tom Woods
Has anyone ordered a rear drive shaft for a 99' or similar from Tom Woods?
I had a 3' Toytech lift several years ago and never had issues but lately I've had some bad rumbling at highway speeds and the typical "clunk" that says it's time to replace ujoints. When I checked I found that the rear ujoint was busted.
The original driveshaft has over 350K miles, so I am considering just replacing the whole shaft, especially after looking at Tim's Ujoint replacement video and getting the general feeling that DIY is less-than-straight forward.
A parts search for an OEM replacement shows that the OEM driveshaft is discontinued (using part # 37110-3D300). I've found a couple sites claiming to still have them, but wanting ~ $700. A Cardone from RockAuto was in the ~ $500.
I've found several posts that seem to indicate the best option for a replacement is Tom Woods. Prices seem good, but the options are bit confusing for me, TBH.
I would appreciate some input on anyone who has purchased from them in the past. It seems my options include:
1) conventional shaft
2) Double Cardan shaft
3) 1350 series Double Cardan
Within each of these choices, there are several other options to choose from:
a) Flange pattern at transfer case
b) flange patter at differential
c) greaseable vs non
d) Tube Wall Thickness
Would appreciate any input, thanks!
[IMG]1999 4WD rear driveshaft replacement Tom Woods[/IMG]
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 08-10-2024, 02:47 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold 2TH4IST is a splendid one to behold
2TH4IST's Avatar
I'm in the same boat, as I've already replace the rear ujoint and the front of the double joint are a bit gritty. I'll be ordering one next pay period.
I'd stick with double cardin joints, you'll need to measure your bolt pattern as toyota has many options across the years. As well as length.
As for tube thickness, it's up to you. What do you use the truck for? Smash your drive shaft into rocks? Go thick wall.
1350 are big joints and I think require different flanges at the tcase and diff. 1310 are standard on his regular driveshafts.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 08-10-2024, 04:51 PM #3
Thanks for the info. I mostly drive pavement (ok, so, I always drive pavement thanks to 80 hr work weeks, lol) so I got the .083. Triple-measured the flange patterns. They came out to 60x60 at the differential and 66x66 at the transfer case. Flange to flange length was 48.5". With tax, it was just a hair under $550.
I'm sure I could have spent an afternoon w/ busted knuckles and swapped out the rear Ujoint, but that double cardan has 350K miles on it so it was probably contributing to the rattle as well.
99' SR5 HRU
Old 08-12-2024, 03:47 PM #4
toverturf toverturf is offline
toverturf has a spectacular aura about toverturf has a spectacular aura about
I've been looking at getting a Tom Woods driveshaft also. You'll have to let us know how it is once you get it installed.
1999 Limited with rear locker.
DuroBumps | OME 890 Springs and Black Tokico Shocks | Bilstein 5100 Front Shocks | Eimkeith Reinforcements and PCK | FGP Rock Sliders
2000 Limited
Sherpa Matterhorn | SPC UCAs | Perry Parts Bump Stops | ASC4243 Springs | Outboard King 2.0 Shocks | Eimkeith Reinforcements and PCK | King Coilovers | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | 4x Innovations Rear Plate Bumper with tire carrier | Addicted Offroad Front Bumper
toverturf is offline   Reply With QuoteReply With Quote
Old 08-13-2024, 12:27 PM #5
3bears 3bears is offline
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Real Name: 3 Bears
I too have looked into his driveshafts for a previous rig. was thinking....if I need one and its not my daily driver....just send him the old one and say....i need one of these
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 09-04-2024, 05:52 PM #6
Ponce11 Ponce11 is offline
Ponce11 is on a distinguished road
The u-joint on my driveshaft wore out and I was getting the clunk while stopping/accelerating and a lot of vibration at 35-65mph.
I replaced it with a Tom Woods shaft and been running it for around 4 years with absolutely zero issues. I grease all of the zerk fittings at every oil change and it's smooth as butter.
It took me about an hour to install, it would have been quicker but rusty/seized bolts slowed the install.
I highly recommend a Tom Woods Shaft.
1999 4WD rear driveshaft replacement Tom Woods-screenshot_20240904-160055-jpg
Ponce11 is offline   Reply With QuoteReply With Quote
rear , replacement , shaft , tom , woods
1999 Sr5 Driveshaft specs bmwahba46 3rd gen T4Rs 1 03-22-2021 12:44 PM
Rear driveshaft grease fitting replacement advice papabeach 3rd gen T4Rs 1 06-10-2017 01:19 PM
Rear Driveshaft Replacement Options 99 Limited Mac_Gyver 3rd gen T4Rs 11 02-28-2017 04:26 PM
REar Driveshaft 1999 limited-$150 TBuzz For Sale: T4R Items 0 03-07-2015 07:46 PM
