Engine oil making way to intake
rukkus0o
Hey all. New member here, joined the board to see if I could get some insight from 4 runner owners about my issue. The truck is a 2000 with 112,345 miles on her.
Somehow I am getting oil up into my intake. First noticed the issue after a stint of about 30 mins on the highway at about 70mph. Came home, went in the house, and the following morning at startup I got a puff of smoke out of the exhaust. This progressed over the last few months. Finally got time today to dig into the issue to try and figure it out.
Changed the pcv with no results. Today took apart the intake tube and upper half of the intake manifold to find this...
Solid amount of oil laying in the intake runners. Also a large amount of oil was in the bottom of the intake resonator box, which I had to drain out.
Checked all of the incomming vaccum lines and narrowed it down to what I think could only be two possibilities. Either the upper hose which comes off of the back driver side of the cylinder head or the pcv valve hose. I popped the back hose off at idle and that seems to be sucking, not pushing air out so not sure oil could be evacuating that way.
The truck idles and runs fine around town. Just after highway jaunts at above 70mph does she smoke after a cool down and refire. I also noticed at times what one would think was detonation or spark plug knock right after getting off the highway and pulling away from a stoplight. At first I thought valve seats were the issue, but then there shouldnt be oil up in the intake.
The only other reason I can think of would be blow by. Some other curious symptoms which have developed is a loss of overall acceleration and occationally right after startup the truck will hesitate no matter how far you push the throttle for about 50 seconds then it idles up and is fine.
Sorry for the long post, just wanted to get all of the info I've gathered into it. Any insight and direction you guys can give me would be mush appreciated!!!!!!!
You posted this in the '4th gen' section. Try reposting this in the '3rd gen' area.
Or better yet, contact one of the Moderators and have them move it for you.
I have been having exactly the same issue for some time now.
97 4Runner Ltd. At first I thought it was the PS pump valve (another forum's suggestion), and after bypassing it, the problem went away...for about a month. Now the smoke plume is akin to a SWAT smoke grenade for the first 15 seconds after startup following a highway jaunt.
I need to pass inspection NEXT WEEK, so I really need to get to the bottom of this.
Other info:
*I just changed my sparkplugs, and #4 (middle, driver's side) was fouled with oil, but the rest had normal wear.
*PS pump valve vacuum hoses are bypassed and capped...no way PS fluid is backing up.
*no check engine lights in many months, and none after I DC'd the battery during my sparkplug/headlight change on Sunday...or appx 175 miles ago.
*oil was changed two days ago...and PCV valve is clear (haven't checked hose yet though).
Sounds like a stuck and or damaged oil ring . Although oil and compression rings are different , if it were me I would do a compression test on your motor and take a look at the results.
Other info:
Start up an old thread
Not to jump on a thread that is dead, but, I have this issue, oil up into the intake manifold ad the half-moon junction. The previous owner had the wrong PCV valve in there, so that may have done it but other suggestions please. What else could this be?
I am taking off the valve covers to replace the gasket, it's leaky and I'm getting a little burning on the back passenger side, and that's when I noticed it.
