11-16-2010, 12:42 PM
Real Name: Justin
Real Name: Justin
Front End Noise when I go over bumps
Hey guys my front end makes this really weird noise when I go over big bumps. It sounds there there is change somewhere in the front end and when I go over a speed bump it sounds like someone is shaking up the change. I checked the upper arm bolts cause I have head those come undone on my old Tacoma and before they did it make a change sound also but the bolts are tight. Anyone have an idea what this could be? Thanks
11-16-2010, 01:26 PM
Sway bar links/mounts?
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
11-16-2010, 01:27 PM
Dude the I've got the same problem...whenever I go over some sort of rigid bump, I hear that awful clanking...cant figure out what it is
1996 Sunfire Red SR5 4X4/3.4L auto/265/75 Cooper Discoverer ATP/Savage Offroad Bumper/LC 7.5 Wraps/Bilstein 5100's/Eibach/Toytec Coils
11-16-2010, 02:33 PM
Real Name: Justin
Real Name: Justin
I will have to check them out. Thanks
11-16-2010, 05:02 PM
Real Name: Phil
Real Name: Phil
Possibly inner tie rods, or the unit they connect to that goes into the steering rack. You can test those be taking the boots off and wiggling the steering wheel back and forth while looking at them. Mine have play in them. Which unfortunately means I need to get my steering rack rebuilt or replaced.
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
11-16-2010, 06:30 PM
I just replaced my inner tie rod as I had a rattle clanging noise when I went over a bump. With the car in the air I could push the wheel and feel movement. I would check for that if a visual inspection reveals everything is connected underneath.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
11-16-2010, 07:36 PM
Check your front body mounts. I had this same problem and realized there were no nuts on the front body mount bolts. Picked some up and tightened 'em down, don't have the problem anymore. You may just need to tighten yours.
'98 SR5 v6 4x4- ARB Bullbar/bumper, OME HD 2.5" kit -881s up front, as well as 3/4" Toytec top plates. -891s in back, Pioneer Navigation, Rear diff breather extension, Shrockworks sliders, Budbuilt front and belly skids, ScanGuageII, deck mod, 285/75/r16 BFG Mud Terrains KM2s
2000 Ltd 4x4 w/ E-locker- Swapping both diffs with my '98
'90 SR5 4x4- SOLD
11-16-2010, 09:07 PM
No rattling here. But, whenever I drive down the road slowly with my window down I hear little squeeks. The squeeking is quite prevailant whenever I go over speed bumps. I just had my shocks, struts, and coils replaced on my front end because my Runner was leaning over a half an inch to one side. I don't know what it is. I figure it's because the truck is 12 years old and, like me, it has its share of grunts and growns.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
11-16-2010, 10:15 PM
Real Name: Jeff
Real Name: Jeff
Same noise here man . I believe its that flimsy protector that covers the fuel lines ? underneath the front , just before they go upwards towards the engine . Its a harmonic vibration . That noise drives me up the friggin' wall !!
1998 4Runner 4WD Ltd
11-17-2010, 02:54 PM
Real Name: Justin
Real Name: Justin
Thanks for all of the help guys. I will check everything you guys suggested. Hopefully I can figure out what it is soon
07-11-2011, 11:20 AM
Real Name: Jeff
Real Name: Jeff
Well... I FINALLY found the source of my annoying rattle/sound. That's been driving me crazy for a year or so now . I did front brakes yesterday and on the passenger side , the part that's known as the anti rattle spring ( Page 9-7 of the Haynes manual , photo 3.5C ) came unhooked from the bottom pad retaining pin for some reason . It's been doing its vibrate , rattle and annoy the **** out of me thing because of that ! New pads , the spring put back in its proper place and a good long test drive and the noise is gone ! I have read quite a few posts here about 3rd Gen owners having an annoying rattle underneath , maybe check it out .
Cheers
XJ
12-26-2014, 02:25 PM
front end noise, 2nd gen
i dont want to spend a lot of money on things that wont fix the problem , but its getting to a point to where i am getting frustrated.
06-22-2016, 07:59 PM
you ever find out what exactly this noise is??? I have the same issue with my new 4runner....going over bumps sounds like change/coins hitting together!! What is it and how can it be fixed?
06-22-2016, 08:13 PM
Real Name: Jeff
Real Name: Jeff
Read my post above . Its easy enough to check .
06-23-2016, 01:37 AM
Real Name: Tim
Real Name: Tim
Cheers
XJ
I had a bad rattle a couple weeks ago, thought my front end was going to fall off. Turned out to be my ANTI-RATTLE SPRING!!
Easy way to check is to break while running over something that usually makes the rattle sound, because the pads will be engaged it won't rattle. If it does then more then like
Y it isn't the break pad spring
'99 5-speed, URD short shifter, Tundra Bilstien/881, 5100/891, TT diff drop, SS Panhard Bar, Studt drop links, Projectors, E-Locked, 231 TBU, Highlander
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
