Old 11-16-2010, 12:42 PM #1
PhdNPrerunners's Avatar
PhdNPrerunners PhdNPrerunners is offline
Real Name: Justin
PhdNPrerunners is on a distinguished road
Real Name: Justin
Front End Noise when I go over bumps
Hey guys my front end makes this really weird noise when I go over big bumps. It sounds there there is change somewhere in the front end and when I go over a speed bump it sounds like someone is shaking up the change. I checked the upper arm bolts cause I have head those come undone on my old Tacoma and before they did it make a change sound also but the bolts are tight. Anyone have an idea what this could be? Thanks
PhdNPrerunners is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 01:26 PM #2
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Sway bar links/mounts?
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 01:27 PM #3
trailhead98's Avatar
trailhead98 trailhead98 is offline
trailhead98 is on a distinguished road
Dude the I've got the same problem...whenever I go over some sort of rigid bump, I hear that awful clanking...cant figure out what it is
1996 Sunfire Red SR5 4X4/3.4L auto/265/75 Cooper Discoverer ATP/Savage Offroad Bumper/LC 7.5 Wraps/Bilstein 5100's/Eibach/Toytec Coils
trailhead98 is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 02:33 PM #4
Real Name: Justin
Real Name: Justin
I will have to check them out. Thanks
Old 11-16-2010, 05:02 PM #5
1985taylor1925's Avatar
1985taylor1925 1985taylor1925 is offline
Real Name: Phil
1985taylor1925 is on a distinguished road
Real Name: Phil
Possibly inner tie rods, or the unit they connect to that goes into the steering rack. You can test those be taking the boots off and wiggling the steering wheel back and forth while looking at them. Mine have play in them. Which unfortunately means I need to get my steering rack rebuilt or replaced.
98 - SR5 - 3.4L - 4x4 - Auto - 4:10 gears
http://www.toyota-4runner.org/3rd-ge...my-runner.html
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
1985taylor1925 is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 06:30 PM #6
rjaudi rjaudi is offline
rjaudi is on a distinguished road
I just replaced my inner tie rod as I had a rattle clanging noise when I went over a bump. With the car in the air I could push the wheel and feel movement. I would check for that if a visual inspection reveals everything is connected underneath.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 07:36 PM #7
StreetKill831's Avatar
StreetKill831 StreetKill831 is offline
StreetKill831 is on a distinguished road
Check your front body mounts. I had this same problem and realized there were no nuts on the front body mount bolts. Picked some up and tightened 'em down, don't have the problem anymore. You may just need to tighten yours.
'98 SR5 v6 4x4- ARB Bullbar/bumper, OME HD 2.5" kit -881s up front, as well as 3/4" Toytec top plates. -891s in back, Pioneer Navigation, Rear diff breather extension, Shrockworks sliders, Budbuilt front and belly skids, ScanGuageII, deck mod, 285/75/r16 BFG Mud Terrains KM2s
2000 Ltd 4x4 w/ E-locker- Swapping both diffs with my '98
'90 SR5 4x4- SOLD
StreetKill831 is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 09:07 PM #8
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
No rattling here. But, whenever I drive down the road slowly with my window down I hear little squeeks. The squeeking is quite prevailant whenever I go over speed bumps. I just had my shocks, struts, and coils replaced on my front end because my Runner was leaning over a half an inch to one side. I don't know what it is. I figure it's because the truck is 12 years old and, like me, it has its share of grunts and growns.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 11-16-2010, 10:15 PM #9
XJeepguy's Avatar
XJeepguy XJeepguy is offline
Real Name: Jeff
XJeepguy is on a distinguished road
XJeepguy's Avatar
Real Name: Jeff
Same noise here man . I believe its that flimsy protector that covers the fuel lines ? underneath the front , just before they go upwards towards the engine . Its a harmonic vibration . That noise drives me up the friggin' wall !!
1998 4Runner 4WD Ltd
XJeepguy is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 02:54 PM #10
Real Name: Justin
Real Name: Justin
Thanks for all of the help guys. I will check everything you guys suggested. Hopefully I can figure out what it is soon
Old 07-11-2011, 11:20 AM #11
XJeepguy's Avatar
Real Name: Jeff
XJeepguy's Avatar
Real Name: Jeff
Well... I FINALLY found the source of my annoying rattle/sound. That's been driving me crazy for a year or so now . I did front brakes yesterday and on the passenger side , the part that's known as the anti rattle spring ( Page 9-7 of the Haynes manual , photo 3.5C ) came unhooked from the bottom pad retaining pin for some reason . It's been doing its vibrate , rattle and annoy the **** out of me thing because of that ! New pads , the spring put back in its proper place and a good long test drive and the noise is gone ! I have read quite a few posts here about 3rd Gen owners having an annoying rattle underneath , maybe check it out .
Cheers
XJ
Old 12-26-2014, 02:25 PM #12
codstr codstr is offline
codstr is on a distinguished road
front end noise, 2nd gen
i dont want to spend a lot of money on things that wont fix the problem , but its getting to a point to where i am getting frustrated.
codstr is offline   Reply With QuoteReply With Quote
Old 06-22-2016, 07:59 PM #13
Stylz Stylz is offline
Stylz is on a distinguished road
you ever find out what exactly this noise is??? I have the same issue with my new 4runner....going over bumps sounds like change/coins hitting together!! What is it and how can it be fixed?
Stylz is offline   Reply With QuoteReply With Quote
Old 06-22-2016, 08:13 PM #14
XJeepguy's Avatar
Real Name: Jeff
XJeepguy's Avatar
Real Name: Jeff
Read my post above . Its easy enough to check .
Old 06-23-2016, 01:37 AM #15
MyHigh's Avatar
MyHigh MyHigh is offline
Real Name: Tim
MyHigh is on a distinguished road
MyHigh's Avatar
Real Name: Tim
Cheers
XJ
I had a bad rattle a couple weeks ago, thought my front end was going to fall off. Turned out to be my ANTI-RATTLE SPRING!!
Easy way to check is to break while running over something that usually makes the rattle sound, because the pads will be engaged it won't rattle. If it does then more then like
Y it isn't the break pad spring
'99 5-speed, URD short shifter, Tundra Bilstien/881, 5100/891, TT diff drop, SS Panhard Bar, Studt drop links, Projectors, E-Locked, 231 TBU, Highlander
MyHigh is offline   Reply With QuoteReply With Quote
Front End Noise BostonBeachbum Problems & Warranty Issues 1 04-20-2009 02:00 PM
04 Sport Front End Noise samIam Maintenance/Detailing 2 05-16-2008 01:41 PM
Front end mtngoat 4th Gen T4Rs 3 04-17-2008 07:36 PM
Front End Restoration HELP WANTED !! skinnadoor Classic T4Rs 3 07-02-2007 04:04 PM
Adding a front end skid plate to my new 06 SE orangeblast22 Off-Roading 3 12-29-2005 11:58 AM
