Old 12-27-2010, 08:11 PM #1
Lowriderman234's Avatar
Lowriderman234 Lowriderman234 is offline
Lowriderman234 is on a distinguished road
4Runner starting problems
Hi, When I go to turn my 4Runner on today it wouldn't start. I had to start the car up for the second try and it starts.... don't know what is going on.
EDIT: So today (1/7/11) it was cold out and I went to remote start the car the starter motor didn't do anything it made a spark sound and nothing happend.
**EDIT #2: Just replaced the new contacts into my starter! Now it runs so perfect now! Special thanks to CoMarc and DH4Runner for showing me what the problem was! Again thank you guys.**
-1998 T4R Limited in Sunfire Red Pearl | 3.4L | 4WD | 99 tall coils with OME shocks | Deckplate Mod |
-2005 Toyota Tundra in Spectra Blue Mica | 4.7L | 4WD | Powerstop slotted and drilled rotors | K&N Series 77 CAI | 17" Gunmetal Tundra/Sequoia wheels wrapped in 265/70/17 BFGoodrich All-Terrain T/A KO |
Lowriderman234 is offline   Reply With QuoteReply With Quote
Old 12-27-2010, 08:22 PM #2
DH4Runner's Avatar
DH4Runner DH4Runner is offline
DH4Runner is on a distinguished road
DH4Runner's Avatar
Contacts in the starter are going bad. Search 'starter repair kit' and you'll find how to fix it. I'm a total newb at car maintenance and I was able to do it in a few hours. There r multiple threads on this here and other places. Example Is your starter going??? Quick and easy repair!!!
If you decide to do this yourself, take note of how you wiggled the starter out so you can tetris it back in the same way.
Oh, I got the kit on eBay for 30 somethin bucks.
good luck
DH4Runner is offline   Reply With QuoteReply With Quote
Old 12-27-2010, 08:23 PM #3
DH4Runner's Avatar
DH4Runner's Avatar
I guess I should mention that this is the fix for when your starter just clicks when you turn the key.
Old 12-27-2010, 08:43 PM #4
tony2no's Avatar
tony2no tony2no is offline
tony2no is on a distinguished road
tony2no's Avatar
Same thing happened to me.
Go check your battery connectors, because one may be loose.
tony2no is offline   Reply With QuoteReply With Quote
Old 12-27-2010, 09:12 PM #5
good luck
Ok thanks I'm going to get some new contacts for the starter sometime next year or this month hopefully.
Old 12-28-2010, 05:14 PM #6
CoMarc's Avatar
CoMarc CoMarc is offline
CoMarc is on a distinguished road
CoMarc's Avatar
Replacing the contacts in the starter are easier than one would usually think. I've done them and I'm not mechanically inclined. See my signature for a write-up I did on it that's pretty simple (with the right tools). If you're just getting a clicking noise when trying to start and no loss in light output then it definitely is your contacts. Good luck!
SOLD 1996 4Runner SR5 - V6 3.4L - 4WD - 5spd - Factor e-Locker
MODS: FJCruiser Rims, 231mm Tundra Brakes, Lifted - Tundra/LC Coils, Toytec Adj Panhard Bar
Other Threads: Starter Contact Replacement
CoMarc is offline   Reply With QuoteReply With Quote
Old 12-29-2010, 07:41 AM #7
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
Hi, When I go to turn my 4Runner on today it wouldn't start. I had to start the car up for the second try and it starts.... don't know what is going on. I think maybe it's the Spark Plugs that needed to be replaced.
So is it turning over when you attempt to start or just clicking or no noise at all? Just wondering since you thought it may be spark plugs? If it's turning over and not starting, I'd say a weak fuel pump.
Deffinitely check all electrical connections such as the permanant hot line connecting the starter to the battery. Also the starter relay in the engine compartment fuse box.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 12-30-2010, 08:32 PM #8
What does turning over mean?
Old 12-31-2010, 05:49 AM #9
DTMtoT4R DTMtoT4R is offline
DTMtoT4R is on a distinguished road
getting a cycle out of the motor.
DTMtoT4R is offline   Reply With QuoteReply With Quote
Old 12-31-2010, 09:03 AM #10
etc.'s Avatar
etc. etc. is offline
etc. is on a distinguished road
etc.'s Avatar
Try turning the key to the on position, but dont turn the truck on. This will prime the lines if you check valve is bad.
But I would try narrowing down the cause instead of purchasing tons of new parts just cause someone said so.
1996 T4R Limited - stock
1997 T4R Limited - stock
2015 TEP w/KDSS - stock
etc. is offline   Reply With QuoteReply With Quote
Old 12-31-2010, 02:02 PM #11
notrayray's Avatar
notrayray notrayray is offline
notrayray is on a distinguished road
notrayray's Avatar
What happened when you turned the key? Click? Nothing? Turning over but not starting?
Mileage?
2001 M. Silver 4WD SR5 5VZ Love Machine
3rd Gen FAQ Here
notrayray is offline   Reply With QuoteReply With Quote
Old 01-04-2011, 07:05 AM #12
Mileage?
long start like eh eh eh eh then it starts
mileage: 96,000
Old 01-04-2011, 12:01 PM #13
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
mileage: 96,000
Then your starter is fine. If you turn the key and you get nothing at all, or a click only then you got bad contacts.
Turning over and not starting is another issue altogether. You could just need a tune up. Could be any one of a number of issues. Does it turn over nice and strong or does it sound weak like the battery is dead?
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 01-06-2011, 03:15 AM #14
notrayray's Avatar
notrayray's Avatar
mileage: 96,000
How long has it been since it's had a tune up?
Sparks are due every 30,000 miles.
Air filter?
Fuel filter?
MAF sensor cleaning?
All things to look at.
3rd Gen FAQ Here
Old 01-07-2011, 11:41 PM #15
Air filter?
Fuel filter?
Just did the Air filter, Fuel filter, MAF sensor cleaning. but spark plugs not yet met 30,000 miles yet.
1998 , 3rd generation , 4runner problem
3rd Gen 4Runner Lift Information and FAQ's steezemcqueen 3rd gen T4Rs 1158 07-20-2026 12:50 PM
Problems with the 3rd Generation 4Runner? a_peep 3rd gen T4Rs 23 12-21-2025 04:39 PM
LIBRARY OF 4RUNNER REVIEWS GatorGreg Comparisons & Reviews 0 02-10-2004 12:10 AM
