Old 03-14-2011, 10:09 PM #1
Antpwr's Avatar
Antpwr Antpwr is offline
Antpwr is on a distinguished road
Antpwr's Avatar
That's IT, I Give UP
Right now i am laughing out of insanity, it is official i have finally lost my freaking mind. I have posted a few threads looking for ideas on how to lift my 99 4Runner, the front no big deal, figured that out in about a minute, but the rear is what is causing me to loose it. I have heard, LC 9 wrap, 850, 851, & 861's. I will have somewhere around 120lbs. of constant weight in the back, while it will go up to around 200lbs. on the weekend when wheeling and long trips with the fam, but i also want at least a 1" rake. So i have been told not to go with the lc's go with the 851's, but researching i found the 850's are taller and handle more weight, so what do i use. Do i go with the 851's, the 861's or try the 850's. If i had money i would just buy all of them and see which ones i like, but i dont. I could use the lc's or the 861's if i put it on a diet, but if i dont then i am guessing i should go with the 851's or possibly try the 850's. Now you can see why i am loosing my mind
Antpwr is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 10:17 PM #2
ReconCmdr's Avatar
ReconCmdr ReconCmdr is offline
ReconCmdr is on a distinguished road
ReconCmdr's Avatar
Making these choices is quite the daunting task! I feel ya! When I did mine I decided to call Toytec and talk with a guy that owns a 3rd gen there. I took his advice and so far have been quite happy with my choice.
ReconCmdr is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 10:40 PM #3
jsmarine's Avatar
jsmarine jsmarine is offline
jsmarine is on a distinguished road
jsmarine's Avatar
Lift and weight support are very different. In my opinion, go with a spring that is designed to handle the weight, not a taller spring that will compress to handle the weight. I have OME 891's in the rear and they are holding up to the weight OK, I have more that 200lbs in the rear with the bumper and cargo box I have. The 891's will lift the vehicle about 2.5 to 3" and support the added weight you have. You can always throw in a trim packer if the lift isn't enough, but at least you will have a heavier duty spring to start.
I would not get a taller spring to compensate for weight, I think they will sag over time.
Keep researching though, it is daunting I know, but its a choice you will have to make yourself. And unfortunately sometimes it is trial and error. We all use our 4runners differently, not everyone is a mall crawler, or a hard core rock crawler, and so lift choices are different.
Keep the thread going, and check with others. I know Brian2sun has had the same problem, with lift and weight, and he wheels pretty hard, more than I do, so check out his latest setup as well if that fits your style. He may chime in here too.
My 4runner - Sold: http://www.toyota-4runner.org/3rd-ge...lots-pics.html
Current Build: 2005 Toyota Tacoma, Crew Cab SB 4x4 http://www.tacomaworld.com/forum/2nd...ld-thread.html
jsmarine is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 11:07 PM #4
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Lightbulb
If you are a do-it-yourselfer and quite brave then browse the forums, pic some coils and hope for the best.
If you have the cash $1200-$1500 order a full lift "kit" from either Toytech or Sonoran Steel. I have a SS 1.2 kit; it came in the mail for $1300 (in 2007) and I installed it with a buddy. I have been happy EVER SINCE.
One common never-ending thread on the forums is people trying to fix their lift kits, swap their coils in order to account for sag or bad ride or something.
What spring should I choose? The answer is going to be based on a lot of factors but if you buy a kit at least you will be buying on for your specific year.
Steve at Sonoran Steel sells each kit customized for the model & year. This is because Toyota actually shipped each year with a different suspension.
If you can afford it buy a kit! You could probably put something together yourself and save $500 but you might have to redo your lift another two times over the next few years as well.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 03-14-2011, 11:07 PM #5
J-money$$$'s Avatar
J-money$$$ J-money$$$ is offline
J-money$$$ is on a distinguished road
J-money$$$'s Avatar
891's just get them chill and install when they come in, They will be just right
edit 891's
its been a bad week sorry for the confusing info
check out my build thread My Build
J-money$$$ is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 02:49 AM #6
flyingyogi flyingyogi is offline
flyingyogi is on a distinguished road
I used the LC coils and it raised the rear more than the toytec coilovers in the front. My logic was that I was going to build a rear bumper(done) and occasionally go camping/wheeling loaded. However I will never put the weight of a straight six LC engine in the back, which these springs will support very well.
flyingyogi is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 04:28 AM #7
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
882's and 861's sit perfect for me. Topouts in the front, 10mm trim packers in the rear.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 08:25 AM #8
smallfry's Avatar
smallfry smallfry is offline
smallfry will become famous soon enough
smallfry's Avatar
Get Steve Schaffer (Sonoran Steel) call and talk to him.
2018 Toyota Tacoma
2010 Toyota 4runner TE - Sold
2002 Toyota 4runner - Sold
2000 Toyota 4runner - rolled
1996 Toyota 4runner - sold a long time ago in a galaxy far far away.
smallfry is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 09:09 AM #9
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Sheesh, yeah there's alot of info, but this shouldn't be that difficult. I agree with everyone else, if you aren't finding the answer here, then just call toytec or sonoran.
You are going to have to trade something off no matter what, and it sounds like you are trying to get a solid 4in of lift in the back with weight, so you are going to have to use something most guys here don't, because most don't want that much lift.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 09:28 AM #10
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
So what front lift are you getting?
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 12:58 PM #11
Antpwr's Avatar
Antpwr's Avatar
i planned on using either the Toytec 3" front or the OME 882 with top out, and i think i am going to try the 851's for the rear, they seem to be fairly tall spring and seem to be able to handle the extra weight without sagging, and i think i will also pick up some trim packers just in case. I think i will be able to get the weight support i am looking for while maintaining a good rake, which i hope will end up somewhere around a 1" difference, and you know what you are right i can always buy some different ones and sell the ones i have if i dont like the setup. But would still like to hear what you guys have to say about it.
Old 03-15-2011, 01:57 PM #12
Just a thought, you can always get air bags for the rear springs to maintain the height while loaded, this would make for a smoother ride when empty.
As you said, sell what you don't like, I see springs for sell all the times on several forums.
Old 03-15-2011, 03:10 PM #13
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
Take it from me (I have the 861s), you want way more than 200 extra lbs. if you want a comfy ride with 861 coils. I have about 700 lbs (~400 in the rear) and it barely even smashes the coils down - and 850s/851s have the same 220# spring rate so they will ride the same. My 861s gave me over 4" of lift with the extra weight. For your 200 lbs., you'd be much better off with LC 8 or 9 wraps IMO.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 03-15-2011, 04:29 PM #14
J-money$$$'s Avatar
J-money$$$'s Avatar
get adjustable colovers like the toytec if your picky on the ride stance. that way you can dial it in. 851's will be perfect. it you want the rake leave the rubber cone/ bumpstop. if you want a more level stance you can run it without that cone bump.
Old 03-16-2011, 04:45 AM #15
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I'm thinking you should do the 861's like Brian and myself. You wont be able to level it out with 851's. Its a 2" lift coil for the 80 series. Plus , like the 861, its got a higher spring rate than the 891's which alot of people run and a thinker coil diameter.
I don't think you'll set anywhere close to level without a ton of weight in the back
‘14 SR5 in white
Full RCI skids
Need Help! Please give me your opinion. scottp999 4th Gen T4Rs 14 07-10-2021 08:23 PM
final questions for a lift - please give your input tineman06 3rd gen T4Rs 11 07-13-2010 08:25 PM
Anybody want to give this a go with photoshop? econhonda 3rd gen T4Rs 10 02-26-2010 08:30 PM
Did i get a good deal for my 4Runner? Slick8810 4th Gen T4Rs 20 10-12-2009 09:25 PM
Give her a bath. Supra725 3rd gen T4Rs 22 07-22-2009 01:38 AM
