Old 03-29-2011, 03:45 PM #1
2002_thundercloud 2002_thundercloud is offline
2002_thundercloud is on a distinguished road
Calling all you Suspension/Spring Gurus
I need some spring advice… I’ve read post after post until my eyes crossed and because most of the posts center around those of you who are doing some type of lift, much of the info is hard to apply to my specific case.
My 2002 Limited 4WD has 80,000 miles. I recently replaced the rear shocks with Bilstein HD’s (a nice and noticeable improvement) and will replace the fronts with the same. It sits perfectly level but the rear springs feel softer than I remember on my 2000 SR5 4WD. On less than smooth roads it feels like it is bobbing up and down off of the big rubber center spring (not the axle stop). Visually there is very little axle travel before the spring seat contacts the rubber spring. It’s like the spring is a bit too soft and the rubber spring is too hard. I have a feeling slightly more spring rate or spring height would eliminate most of that bobbing feeling from the rear. And just because… I will replace the front springs while I am replacing the front shocks.
All that to say I need some advice/recommendations for: 1.) Front springs that are generally the same rate and height, a very slight increase in either is o.k. 2.) Rear springs that are just slightly higher in rate and/or height. My thought being that the ride and drivability will improve if I can keep the axle from contacting the rubber center spring so frequently. It’s a daily driver 80% of the time so I would like to retain a decent unloaded ride. I don’t mind a minor increase in ride height or spring rate, as long as the rear remains level or just slightly higher than the front.
Thanks for any advice you have.
2002 Toyota 4Runner 4WD Limited. 89,000 miles. 880/906 OME springs. Bilstein 5100 Front Tundra / HD Rear 4Runner shocks. Wheeler steering rack bushings. Tundra 231 disc/caliper upgrade.
2002_thundercloud is offline   Reply With QuoteReply With Quote
Old 03-29-2011, 03:58 PM #2
DH4Runner's Avatar
DH4Runner DH4Runner is offline
DH4Runner is on a distinguished road
DH4Runner's Avatar
I'm sure you will hear 1) '99 model tall springs all around and 2) OME 880 or 881 in front and OME 906 in the rear.
Good luck
'96 Limited 4x4 - Toytec Ultimate - 265/75/16 BFG's
DH4Runner is offline   Reply With QuoteReply With Quote
Old 03-29-2011, 04:22 PM #3
fenrisx's Avatar
fenrisx fenrisx is offline
fenrisx is on a distinguished road
fenrisx's Avatar
I can't say since I've never used the shocks you're using, or ran 99 talls... so just for reference here are the part #'s for the tall springs if you decide to go that route.
FR Springs - Blue / Yellow (48131-35400)
FL Springs - Blue / Pink (48131 - 35350)
REAR Sprigs - Yellow / Red (48231 - 35210)
fenrisx is offline   Reply With QuoteReply With Quote
Old 03-29-2011, 05:43 PM #4
J-money$$$'s Avatar
J-money$$$ J-money$$$ is offline
J-money$$$ is on a distinguished road
J-money$$$'s Avatar
that rubber cone is a bump stop not a spring. when that contacts its called bottoming out.... YOUR SPRINGS ARE SHOT
check out my build thread My Build
J-money$$$ is offline   Reply With QuoteReply With Quote
Old 03-30-2011, 01:29 PM #5
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
My experince
with the rear 99 talls was that, with the HDs they were really soft. I replaced um with 906s and the rides great. I think the 880s provide .25" more lift then the 99 tall fronts and there cheaper if your buying new.
jrm is offline   Reply With QuoteReply With Quote
Old 04-04-2011, 02:29 PM #6
Pulling the trigger....
So after all the reading... I think I'm going with:
FRONT - OME 880 / Bilstein HD 24-187244
REAR - OME 906 / Bilstein HD 24-024518
I'm hoping this will firm up my ride just a bit over stock and give me just a little lift, but I don't want it to look "lifted". I also want it to sit level or just slightly higher in the rear. I'd love to hear from those that have used this combination of f/r springs on their ride, even if you didn't choose the bilsteins. Are you happy with the setup? Would you change anything?
Regarding the big rubber cone thing in the center of the rear springs. Seems like some of the pics I've seen posted by guys doing lifts do not show it. Is it part of the spring seat? For those who have replaced their rear springs... did you leave the large cone in the spring seat? Someone mentioned it was a bump-stop. The square block slightly outward of the spring is what I'd call a bump-stop. This cone-thing may act kind of like a bump-stop, but it also compresses like a spring when the steel springs compress enough to contact it. Do all 3rd gen 4Runners have that cone?
Old 04-04-2011, 05:00 PM #7
blcktpgsr's Avatar
blcktpgsr blcktpgsr is offline
Real Name: Ervin
blcktpgsr will become famous soon enough
blcktpgsr's Avatar
Real Name: Ervin
I am by no means a Suspension Guru but others have called it spring cone isolators or bump stops and AFAIK will cater you approx. another 3/8 - 1/2" of rear lift.
I'm pretty sure all 3rd Gens came with them, some lifted truck owners choose to leave them in for the extra free lift(I did), some didn't. All depending on the front vs. rear suspension set up and how you want your truck to sit. Metal to metal contact is the other issue associated without it and from what I read- feels more like the springs are shifting during articulation,(e.g. over bumps etc...)causing some clanging noise.....enough to bother some!
Bottom is that 1/2" of extra lift is very negligible and if your the type that loads up your cargo, then that's another bonus.
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build
http://www.toyota-4runner.org/3rd-ge...formation.html
July 2012 T4RoTM / 2012 T4RoTY
blcktpgsr is offline   Reply With QuoteReply With Quote
Old 04-04-2011, 05:39 PM #8
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
Those center cones are as far as i know the "overload" springs and the actual bump stops are on the frame.
as other have suggested 880 or 881 front with 906 or 890 rears would be great for you. if your looking for closer to 99ish height, 880s+ 906 would be a good bet.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
twitchee2 is offline   Reply With QuoteReply With Quote
Old 04-04-2011, 07:45 PM #9
jksmyers's Avatar
jksmyers jksmyers is offline
jksmyers is on a distinguished road
jksmyers's Avatar
I'm also trying to decide between OME 880/906 and 99's all around. I'm surprised to hear that OME's are cheaper. That just made my decision for me.
jksmyers is offline   Reply With QuoteReply With Quote
Calling all White 4runners, post your pics!!! MSBX4RUNNER 4th Gen T4Rs 189 12-31-2021 11:40 AM
Calling all you electrical gurus!!! fightman80 3rd gen T4Rs 17 03-21-2011 02:47 AM
Calling All Lower Mainlander Runners!!! afx604 Vancouver / British Columbia 16 01-14-2011 04:18 AM
Calling all ScangaugeII owners!!! Full_Throttle 3rd gen T4Rs 4 06-24-2010 05:45 PM
Calling all parents on this board.... Fortyounces Off Topic 21 04-10-2005 09:55 AM
