Question about front shocks
Atreyus
So I'm planning on getting these.
Front Bilstein Height adjustable front 5100 shocks - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Mainly because I think My KYB Gas-A-Just shocks are getting over extended? There too short and are making weird noises up front. I have a 2.5" Daystar lift, would setting these shocks at 2.5" increase the front lift? Or what would be the best settings for a 2.5" Spacer up front? Any info would be greatly appreciated thanks!
you should probably leave the perch setting for stock if you will be using it with spacers, but you might be able to get away with the 1.25" setting since you have a 2wd (no abnormal cv angles).
