98 keyless entry
RyanCrotty
Hey i just bought my 4 runner a couple of days ago and its a 98 limited, it was missing the keyless entry remote and i have a freind who works at the dealer and he hooked me up with two remotes, Can i program it my self with out having to pay the dealear ship 75 dollars per remote to do it , any help would be great thanks
Ryan
i have no idea, i just thought id let you know, i had mine 30 days then the alarm system(stock) went haywire and we took it out
Here you go
The search engine is your friend.
Or as my daughter says, I don't need to study, I've got google.
1. Start with the following conditions: you are seated in the vehicle
a. Key is out of the ignition.
b. Drivers door is open, all other doors are closed.
c. Drivers door is unlocked.
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. cycle the power locks 5 times, evenly spaced and relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. cycle the power door locks 5 times. (Same as before)
b. Turn the ignition to on, then back to off.
c. Turn the ignition to on, then back to off.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically) indicating successful entry into programming mode. Return to STEP 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful programming. If the door locks don't cycle, or cycle twice, repeat steps 6a and 6b - this remote has not been accepted.
c. Repeat steps 6a and 6b for each transmitter that will operate this vehicle, including any old transmitters.
7. Close the driver door.
