Head gaskets
ToyNutt
Changed my oil today and noticed my passenger side HG beginning to leak pretty good. What are the best gaskets to get and how long of a job should it be to replace? I can do the work but with working 7 daw I don't have time. Just wondering if I should take it to the shop or take a day of work. Any idea of what a shop would charge?
What are you seeing leaking, oil or coolant? Does your oil look like chocolate milkshake?Is there excessive water and/or white smoke coming out of the exhaust? Loss of power? Are you loosing coolant?
It's a common noob mistake to think valve cover leaks are head gasket leaks, so are you sure it's not just your valve covers that are leaking? That's a helluva lot easier and cheaper task. HGs are an expensive, very labor intensive job. You'll be looking at anywhere from $1500-$3000 depending on what shop you take it to if it is actually a HG leak.
Guy I know at local Toyota dealer said $250 with parts. Is that a good enough deal to keep me from doing it? Looks like a lot of s!*# to remove just to get to the covers.
