Old 03-07-2005, 01:27 PM #1
voltageGSR voltageGSR is offline
voltageGSR is an unknown quantity at this point
VSC Trac/off light - and check engine
Hey guys
I have a 2001 SR5 with 71,000 miles - bought
it a few months ago.
Was running great until this morning - a lot of rain..
drove over a pretty large area of water a few minutes
later the VSC TRAC and OFF button both came on! as well
as the check engine light. I ran the codes at Autozone and got
P0446 and P0441 (EVAP Emission control vent circuit malfuction)?
No idea what this means. Before I take it to the dealer I want
to check with you guys to see what I should do?
Thanks in advance
2001 Toyota 4runner SR5 4x4
voltageGSR is offline   Reply With QuoteReply With Quote
Old 03-07-2005, 03:05 PM #2
lee's Avatar
lee lee is offline
lee is on a distinguished road
lee lee is offline
lee's Avatar
"Just in case anyone was following this thread, I went to my appointment at the dealer today and it turns out the problem was along the lines of what MTL suggested. The VSV valve was stuck open. Replacement part $44, labor $150. "
http://www.yotatech.com/showthread.p...ighlight=P0446
Thats for the P0446 code.
another helpful thread:
2006 4Runner Sport 4wd
XREAS
JVC kw-nx7000 head unit
lee is offline   Reply With QuoteReply With Quote
Old 03-07-2005, 03:41 PM #3
toyoboy toyoboy is offline
toyoboy is an unknown quantity at this point
check your gas cap if its on properly. then pull the efi fuse or
disconnect the battery, this will clear your codes. then use the vehicle. if the light comes back on bring it to the dealer.
toyoboy is offline   Reply With QuoteReply With Quote
Old 03-07-2005, 05:01 PM #4
lee's Avatar
lee lee is offline
lee lee is offline
lee's Avatar
he already pulled a code... which can then be diagnosed.
XREAS
Old 03-07-2005, 07:51 PM #5
lee-
thanks!
why is the labor so high? I went and looked under the
hood - the VSV valve seems like its right there??
Also I called my local stealer and they want $75 for the valve and $186 to replace it??? Am I missing something.
i was going to pull the valve - check all the hoses to make sure they are good and replace the valve - reset the codes and see if still triggers. If so - the canister might need to be replaced - or I read here that it could be as simple as having topped off the gas tank.
any suggestions? how to replace?
thanks!
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 121 10-23-2025 12:43 AM
VSC off, TRAC off and check engine light on! swimmer2361 Problems & Warranty Issues 78 09-01-2020 10:21 PM
once again - VSC Trac/off light - and check engine RagingBullNYC 3rd gen T4Rs 9 06-07-2010 07:39 PM
check engine light + the VSC Trac + VSC OFF lights are on- Again 1 year later Jerold 3rd gen T4Rs 22 05-26-2010 02:11 AM
VSC, VSC OFF light, no check engine blackt4r 3rd gen T4Rs 3 06-28-2007 01:39 AM
