Old 07-11-2011, 07:14 PM #1
chainring chainring is offline
chainring is on a distinguished road
When y'all do a Tundra 231mm brake upgrade...
...do you guys just buy the rebuilt units from the Napa, etc. or shop for used ones at the wrecking yard? I found a set of used calipers at a wrecking yard that can be had for $75 for both. The cheapest remanufactured units I found were about $150 each. Factory parts bought new are over $400 each. What's the word?
In addition, are normal Brembo rotors worth the $100 or so each, or should I just buy the generic $50 units at the local parts store? Or find the "slotted Brembos" that I see some folks referring to in build threads? Or some other brand? I did a quick search, and regular Brembos seem plentiful, but slotted stuff isn't just jumping off the page at me. Any reliable sources for that sort of thing. Several of the threads I've seen have mentioned "backordered slotted Brembos" too, so maybe they are a bit of a problem to find.
Thanks for your help!
chainring is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 07:21 PM #2
rjaudi rjaudi is offline
rjaudi is on a distinguished road
I am using junkyard units with great success. Put a new set of OEM pads in them and have worked great. Don't waste money on slotted rotors. The junkyard I went to had 2 rotors with 26k miles on them for 50 bucks. I painted them and had them turned. Worked great. Some people buy from NAPA then return their old 4runner calipers as cores. You may get lucky and that will work.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 08:05 PM #3
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
I got my 231mm calipers at Autozone for $79.99 each after the core and they are lifetime warranty too. The core was $75/ea. on my old 4runner calipers and I had no problem returning them.
I went with Napa premium rotors ($51.99/ea.) and Napa ceramic pads ($44.99 for the set of 4). I also got the 10% AAA discount on top of that at Napa. I saved ~$50 by buying the calipers at Autozone instead of Napa and both brands are lifetime warranty so that was a no brainer. I like the idea of buying new/reman calipers with a warranty over junkyard calipers.
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 08:23 PM #4
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
Napa 231 calipers, Napa Premium rotors, Napa pads. Total was $378
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 09:18 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I have heard success stories from both sides of the fence. I got my 231s off an 06 Tundra, bought a Toyota OEM rebuild kit, and have been trouble free from day one except for the mushy pedal initially.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 09:27 PM #6
Thanks, y'all.
Toyota OEM rebuild kit? Easy install? Didn't know there was such a thing. Interesting..
Old 07-11-2011, 09:35 PM #7
I had a torn boot around the piston. I think the rebuild kit runs $30~$40 per caliper, or it may be for two calipers. If no boot tears, or leaks, just mount them and move on.
Old 07-11-2011, 10:03 PM #8
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
I guess while we're talking about this...
I know cross drilled/slotted etc etc rotors are nice but are they worth it? They way I look at it is, I'm not doing any kind of racing but I do a lot of harder offroad stuff. With 285's, bumper, skids, and all the possibilities to add more armor... the weight adds up. Essentially it's like being stock pulling a seadoo or 4wheeler all the time. So would it be beneficial for me to get better rotors rather than just getting plain "blanks".
Brian, I know you and I are kind of on the same level with offroading. You seem to be pretty happy with your brake setup?
I've got a really good buddy (manager) at AutoZone and he sometimes hooks me up if I'm spending a good chunk of money. So I plan on doing most the shopping there if I can.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 07-11-2011, 10:33 PM #9
brian2sun's Avatar
brian2sun's Avatar
Yes, I'm very happy with my setup. And, I even have a leaky rear axle seal so I know my back brakes aren't working as good as they should be. These Tundras rock! I've never had slotted rotors, but one thing I noticed on the Tundras is the pad retainer spring is like a big paper clip on the Tundras whereas it's a big wide metal plate on the 4runners. That alone lets the "fins" (or whatever you call them) inside the Tundra rotor get way more airflow and keep cooler.
Old 07-11-2011, 11:09 PM #10
Don't believe any boots were torn, and didn't see any leaks...the boots were a bit baked by the sun, though. Guess I could put 'em on and see how they did. Rebuild 'em if they start leaking, etc.
Old 07-12-2011, 10:05 AM #11
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
good to know.. the only couple drawbacks I have with slotted/cross drilled rotors is I would think they wear down the pads a little quicker and I might not have the application to benefit from them. I'm willing to give them a try though. I'm sure anything is a lot better than what I have now.
Old 07-12-2011, 10:38 AM #12
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Blanks offer more swept area for the pad to act on, so they will allow you to stop faster than slotted/drilled. New technology brake pads don't off-gas the same way they did 10+ years ago, so slotted/drilled rotors aren't needed the same way they were back then when they would help evacuate the gasses. Drilled rotors are also prone to cracking, and both slotted/drilled will wear pads down faster. Good quality blanks are the way to go these days.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 07-12-2011, 11:26 AM #13
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Yeah, I'm no expert on slotted vs blank rotors, but you do have to be careful with slotted rotors to make sure you get good ones that were cast with the slots in the mold vs machined slots. Machined slots are bad because they can leave residual stress and are more prone to cracking than cast slots. Assuming what IanB said is true (I have no reason to doubt it) then, the performance difference would be even less with modern pad materials.
Honestly, I have never heard of consumer vehicles needing slotted rotors. They have mostly been for race cars and high performance sports cars. Lots of heavy quick braking, and those were very expensive rotors to be sure. Doesn't seem worth the cost to me.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 07-12-2011, 11:27 AM #14
binhsterbinh's Avatar
binhsterbinh binhsterbinh is offline
binhsterbinh is on a distinguished road
O'Reilly Auto 231mm A1 Cardone Remanufactured Calipers: $150/pair
Centric Fleet High Performance Pads (previously badged Stoptech Street Perfomance) -$58 shipped Rock Auto
Centric Slotted Rotors (non cryo) with E-Coat- $195 shipped Streetsideauto with coupon
Since it was $50 difference between Centric Premium vs Centric slotted, so I got the Slotted instead. No regrets - they look great regardless of performance drawbacks/gains.
Stopping power with Fleet Performance Pads are very linear and increased pedal travel due to larger calipers makes it easier to modulate braking force.
I grinded my split 3 spoke wheels using 4.5" Angle Grinder I bought for the purpose.
binhsterbinh is offline   Reply With QuoteReply With Quote
Old 07-12-2011, 12:28 PM #15
brian2sun's Avatar
brian2sun's Avatar
For whatever reason, my pedal doesn't/didn't feel mushy or feel like I had increased pedal travel after the Tundra swap. At least not any more than it was with normal brakes. I know most people say they feel that, but the only difference I feel is my brakes stop easier and there is virtually no brake fade.
231mm or 199mm Tundra upgrade reeseozan 3rd gen T4Rs 22 12-25-2017 03:37 PM
231mm Tundra Brake Swap COMPLETE! CoMarc 3rd gen T4Rs 52 07-14-2017 10:33 PM
Tundra brake upgrade help whodini 3rd gen T4Rs 18 06-10-2011 07:53 AM
Tundra 231mm Front Brake Swap Lignum 3rd gen T4Rs 3 04-20-2010 04:35 PM
