09-06-2011, 12:29 AM
Snorkel Position Question
“The great snorkel debate”
I’m sure this has been brought up before, but is there a consensus on when you should have your snorkel facing forward versus backward? I’ve heard that you should run it facing to the back if snowing but in the rain forward: I don’t understand why but there you have it. It would seem if traveling in a group off road in a dusty/sandy environment you should face it to the rear to avoid clogging up your filter prematurely. Does facing it forward give you a better flow of air into the engine like a ram intake? Does facing it backward, make the engine work harder getting air in?
Ok thanks, I think that is about it.
Anyone changes their snorkels position based on weather, trail etc?
Josh
98 4runner. L.A.M.B. (locked, armored, methanol injected & blown) URD 7th & 2.2 pulley, meth injection, ARB bumper & lockers, Warn 9.5xp winch, yukon 4.88 gears, rear disk conv, blah,blah, blah blah [B]SOLDB]
93 Hilux Surf, 3.0 kz-te, restoration in 3, 2, 1
09-06-2011, 12:33 AM
I think the main reason people face it to the rear is to avoid grabbing every limb on the trail.
2000 Limited Sports Edition, 285-75-16, TOYTEC Adjustable Front Coilovers, OME 891 & Bilstein 5150's rear, TOYTEC 1' Differential Drop, E-Locker, 4X4, 4.56 Gear Ratio, Tundra 231 Brakes, All-Pro Apex Front Bumper, OL Rear Swing-Out, 4X Innovation Sliders, Savage Offroad Skids300K, JVC Radio, Tacoma Whip, CB Radio
09-06-2011, 04:01 AM
Well the whole point of the snorkel is to keep water out of the airbox right? I run with mine forward facing for the most part but if I know I'm going out to trails where I'll be bajaing through puddles I'll turn it backwards, no point is splashing water in there. I do notice a very slight loss in power with it flipped around. But the slits in the Safari head keep the majority of rain out. A lil water wont hurt it. I completely saturated the old paper filter before the snorkel and it was still running fine, now I have a K&N. It can get wet and just dry back out.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
09-06-2011, 09:51 AM
The only thing that I have heard is to turn it around in the snow to keep it from getting packed tight.
I know that the Safari Snorkel head sheds water.
Safari - Snorkels (scroll down)
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
09-06-2011, 11:24 AM
Thanks everyone and thanks chris for pointing out the link.
