Old 09-22-2011, 01:45 PM #1
dgoll75's Avatar
dgoll75 dgoll75 is offline
dgoll75 is an unknown quantity at this point
dgoll75's Avatar
Battery Drain Problems
Hey guys I posted something similar before but I am still having issues. I have a brand new battery, a year old alternator, and a freshly rebuilt starter. All connections are tight and wires look fine. My T4R is a 97 with 150k and is awesome in all other aspects except if I let it sit for about 48 hours without being driven or started it will loose its charge almost completely to the point of not starting. If I drive it everyday it seems fine. This sucks because I use it as my weekend driver. I live in FL and the weather is not a factor (80-90 everyday). I do have an aftermarket stereo and I make sure to turn it off before I turn the ignition off just in case. No help. I have never seen a truck do this. Any suggestions?
dgoll75 is offline   Reply With QuoteReply With Quote
Old 09-22-2011, 02:33 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Have you had the new battery tested? I've seen new batteries that were no good.
02SE is offline   Reply With QuoteReply With Quote
Old 09-22-2011, 02:33 PM #3
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
as far a troubleshooting goes I would try this:
you need to determine if the problem is a voltage drain or a failure to charge the battery.
so charge the battery using a 120v plugin charger. Then at 6pm hook the battery back up to the car. if the car starts fine in the morning, that is a good sign but repeat the next night just to be sure. Batteries can be unpredictable.
if the battery only holds a charge using the above method vs normal driving to charge the battery, then perhaps your alternator is not able to charge the battery properly.
(sent from droid x)
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 09-22-2011, 06:32 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
Suggestion above is good. You could also just try leaving the negative cable off for 48 hours and see if it starts strong when you reconnect. If it does, then you know you have a parasitic drain, which is also a good search term for finding out how to track it down.
When you reconnect the battery, listen closely for any relays clicking. I had a set of Hella fogs where the included relay plug was mis-wired and the relay coil stayed energized 24/7. It would run the battery down in almost exactly 48 hours. It was the clicking when I connected the battery that eventually gave it away when I started parasite hunting. As far as I know, no relays should energize just from connecting the battery. That wouldn't make any sense.
My Backyard Frame Swap
Old 09-23-2011, 09:55 AM #5
dgoll75's Avatar
dgoll75's Avatar
Great advice guys. Im going to try that this weekend. I will keep you all posted.
Old 10-09-2011, 01:52 PM #6
dgoll75's Avatar
dgoll75's Avatar
My Amplifiers were to blame guys! For some reason the 2 amps were drawing power while off.... Not sure why. 1 $5 cutoff switch and problem solved. Thanks for all the input.
battery , problems , starting problems
Huge Parasitic Battery Drain Problem pax 3rd gen T4Rs 36 07-04-2019 05:19 PM
Strange Battery Drain HELP dgoll75 3rd gen T4Rs 8 02-27-2011 06:04 PM
Strange battery drain Red Classic T4Rs 4 09-02-2009 09:33 AM
'98 Battery Drain jranger35 3rd gen T4Rs 12 03-11-2008 08:10 PM
New battery problems? pcmsurf Problems & Warranty Issues 1 10-01-2003 12:19 AM
