Headlight Projector Mod vs. Buying OEM 2006+ Headlight Assembly
I want to get both the 4300K HIDs and projectors for my 2005 Limited with DRL. After doing a lot of reading on here, it seems many of you have done a projector mod from a TSX or some other headlight. Is there any reason to do this over just buying the 2006+ OEM replacement headlights? Is it cost? Is the late model headlight assembly not a plug-and-play in the 2005?
I'd like to keep this mod as simple as possible...even if it may cost a bit more initially.
Thanks in advance...
___________________
2005 Limited V8 - Natural White
18" Limited Wheels
LED Swap In & Out
Map Light Mod
TSX Projector Low Beam Retrofit - Phillips 85122 Bulbs - Gatling Gun Shrouds
20% tint on driver/passenger doors
