Thread: keyless entry
View Single Post
Old 03-31-2009, 03:51 PM
01t4rnr's Avatar
01t4rnr 01t4rnr is offline
01t4rnr is on a distinguished road
01t4rnr's Avatar
I dont have a box under my seat and i have keyless entry option. I bought the truck used and it didnt come with remote but started doing some research and if you follow this code and your locks respond- you have the option:
** from another site, these are the programming instructions
The vehicle should be in the following conditions
1. The key is not inserted in the ignition key cylinder.
2. Drivers door is open (other doors are closed)
3. Drivers door is unlocked
Insert the key into the ignition key cylinder, then pull it out
Within 40 secs.
Press the door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1sec. Interval
1. Lock then unlock
2. Lock - unlock
3. Lock - unlock
4. Lock - unlock
5. Lock - unlock
Close the drivers door, then open it. Again press the door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. Interval
1. Lock - unlock
2. Lock - unlock
3. Lock - unlock
4. Lock - unlock
5.lock- unlock
Insert the key into the ignition key cylinder.
Turn the ignition switch from on to lock at approx. 1 sec. interval 1 to 5 times to select the mode.
Add Mode
ON - LOCK change occurs 1 times
Confirmation mode
ON - LOCK change occurs 3 times
Rewrite mode
ON - LOCK change occurs 2 times
Prohibition mode
ON - LOCK change occurs 5 times
Pull out the key plate from the ignition key cylinder
When add mode or rewrite mode is selected.
Body ECU automatically performs the LOCK-UNLOCK operation once or twice at 1 sec. interval to inform the operator that either the add mode or rewrite mode has been selected
LOCK-UNLOCK occurs once indicates that add mode has been selected
LOCK-UNLOCK occurs twice indicates that rewrite mode has been selected
Press the lock and unlock switches on the transmitter
2001 4 Runner 4wd SR5 v6 auto. TRD Tundra coils,adj. Bilstein 5100's, 8 wrap LC coils, 15% tint, Hella 500's, Skyjacker Nitros, 285/75/16 Mud Dawgs, 16x10 rims, B&M 70268
01t4rnr is offline   Reply With QuoteReply With Quote
